20 Most Recent
Imperial ICV-1 Turbo-Flow Single Oven Questions & Answers
Our kitchen uses the Imperial IVC-1 after it
Not sure if you have electronic or mechanical thermostat. However problem is likely to be in the electronic ignition sequence box (Usually a Fenwall) Also check the panel cooling fan is working, it cools the Fenwall box.
How do you adjust doors on imperial ICV-1 convection oven
The turnbucke system behind the lower panel is relatively straightforward but one buckle is LH thread the other is RH thread. Slacken both locknuts and adjust the buckles until the LH door lags by the thickness of the RH door when they are just coming together (a rough approximation). Don't have too much tension on the chains and lube the chains, gears etc with a copper based grease. It has been known for the little grub screws in the bottom cogs to come loose. You'll need an allen key to tighten them up.
After all adjustments check the chain 'slack' by quickly opening/closing the doors when at about 1/2 open. There shouldn't be so much that the LH door doesn't react reasonably quickly to the change of direction, but not so tight as they are like bow strings.
The lowest setting on the
The temperature figures on the dial are a guide only. Play with the dial, you will pick up where the thermostat cuts in and out. 130 deg. is rather low, but it could be achievable. You will only find out through experimentation - nothing will be damaged.
