20 Most Recent Western Digital Caviar SE WD2500JD 250 GB Hard Drive Questions & Answers
My WD External Hard drive was working
Get a new case for the drive. Empty cases can be had from any store that sells computer parts.
8/16/2017 4:35:28 PM • Western Digital... • Answered on Aug 16, 2017
Dear respect sir
You have the wrong site. Fixya does not accept things for repairs, we offer advice online.
6/12/2017 5:30:35 AM • Western Digital... • Answered on Jun 12, 2017
Computer; Medion MD8383 Windows XP
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
hope this helps you
8/3/2011 8:42:55 PM • Western Digital... • Answered on Aug 03, 2011
The drive does not appear on My Computer, thus I
One bad/faulty lead can cause a computer with lots of problems replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
10/3/2010 4:35:20 AM • Western Digital... • Answered on Oct 03, 2010
2answers
Hard drive does not spin up and ciruit board heats
You can try replacing the control PCB make sure that you get the exact model and firmware replacement you can get these on e-bay quite easily you will need a star drive set to remove it and an antistatic wrist strap this make be all that is required. If your motor still wont spin after this then you don't have much hope on retrieving your data you can try the fridge trick overnight in a ziplock bag then try to recover to a new HDD
3/31/2010 12:58:02 PM • Western Digital... • Answered on Mar 31, 2010
I want to set this up as a slave drive in my Dell
this is a SATA HDD, so to make it a Slave drive, it will need to be on the SATA-1 or later controller (The Boot Drive should be Sata-0)
3/19/2010 8:23:20 PM • Western Digital... • Answered on Mar 19, 2010
Hi i had a advent t9401
The WD2500JD series are 3.5"
1/20/2010 7:00:37 PM • Western Digital... • Answered on Jan 20, 2010
Not seeing that the fdisk is 80gb it is saying
it is possibly set as 2 partitions possibly f and g
12/27/2009 5:47:17 PM • Western Digital... • Answered on Dec 27, 2009
I have two mirror drives in a dell 360 workstation
dear sir good day you must buy a HDD with the same configuration and the same size or bigger to make this mirror work thank you
12/27/2009 12:19:14 AM • Western Digital... • Answered on Dec 27, 2009
It seems that the fuse for that board has blown
I don't know if WD are like Maxtor but M won't supply you with a replacement pcb - they want you to buy a new drive.
If you can find an IDENTICAL WD drive buy it. Take care and remove the circuit board from the new drive. (It's very straightforward). Now remove the circuit board from the duff drive and replace it with the board from the new drive.
Plug it in and test. Does it work? Does it mount?. Now copy all the data from the drive onto something else as a priority. Once you have completed the transfer, remove the drive, remove the circuit board and refit it to the new drive. Mount the new drive, format it and then copy all your files back again.
Use the new drive and keep the old for safe-keeping.
The only thing that can go wrong (other than being ham-fisted) is that there is a problem with the old drive that has caused the fuse to blow and it could well cause the fuse in the new Circuit board to blow. But that's a chance you've got to take if you want your data back.
9/22/2009 7:37:00 PM • Western Digital... • Answered on Sep 22, 2009
2answers
I want to know the jumper set up to make the hard
8/29/2009 12:10:42 PM • Western Digital... • Answered on Aug 29, 2009
I have a 2.5
In the back of my head, I seem to remember a jumper setting, limiting to 32Gb. WD usually has their drives plainly marked. A trip to their website will confirm or disprove. The reason I think that this is the answer is that PM only sees 32Gb.
8/18/2009 2:34:12 AM • Western Digital... • Answered on Aug 18, 2009
Platter not spinning when powered on
Hard drive can make a nice paper weight. It's toast.
8/16/2017 4:58:41 PM • Western Digital... • Answered on Aug 16, 2017
No Power Spin-up
No diagrams or parts. WD may be able to repair it for you.
8/16/2017 4:57:03 PM • Western Digital... • Answered on Aug 16, 2017
What is the third external connector besides the power and SATA connectors ?
In some cases an IDE connector is added to RAID Hard Drives or Industrial grade desktop computer drivers.. it's a backwards compatibility measure in case of failure. Other driver may also include an IDE power source too.. Those IDE connections are also known as (PATA) or Parallel.
11/21/2014 8:53:01 AM • Western Digital... • Answered on Nov 21, 2014
How to repair dead external pc Harddrive?
WARNING Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive power and data cables IDE ,SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd \ cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ http://www.youtube.com/watch?v=du0Qd_3wFWM
7/30/2013 5:02:06 AM • Western Digital... • Answered on Jul 30, 2013
One short beep one long beep coming from hard drive
..as i know when HDD start beeping ( internal or portable ) that indicate problem with the Hard Drive (HDD)..so nothing you can do it by your self ....if the HDD is under warranty from factory you may take it to the store that you buy or nearest Western Digital distributor to claim the warranty...but if it doesn't in warranty..that's mean a problem why?because if HDD start beeping like you have, the possibility to make it work again is almost impossible that mean you maybe lost the data that you save in this HDD..
9/3/2012 6:07:17 PM • Western Digital... • Answered on Sep 03, 2012
Wd5000aavs tries to power up then goes out
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
8/4/2012 6:19:30 AM • Western Digital... • Answered on Aug 04, 2012
How do i format a sata11 hard for use in another pc in windows xp pro 32 bit
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd hope this helps
7/13/2012 7:55:31 PM • Western Digital... • Answered on Jul 13, 2012
Western Digital Caviar SE WD2500JD 250 GB Hard Drive Logo
19 questions posted
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Caviar Western Digital
  • Caviar Western Digital
Most Popular Question
hard drive not spin up ciruit board
  • Computers & Internet
