20 Most Recent
LG Home Applaince LG SteamDryer DLGX2802R 7.4 Cu. Ft. Steam Gas Dryer - Wild Cherry Red Questions & Answers
Remote not working at install Casa Turbina DC 60
Do you have a phone with a front facing selfie camera? Face the front of the remote at the camera and press a button. You should see a flash. If you don't, the batteries need changing or the remote has failed.
4/21/2024 12:53:31 AM •
Dryers
Answered
2 days ago
Holmes HSF1610A 16" floor-standing fan. Replacement part for my fan?
No replacement parts generally, and all are obsolete. Holmes themselves send people to eReplacement parts, and they say obsolete. Fix with Epoxy adhesive or putty, or have the part 3D printed or buy new one.
e Replacement Parts
Holmes Products
https://www.holmesproducts.com > e-replacement-parts
Replacement Parts. The link below will take you to a site outside of Holmes. ... Call 1-888-472-5853 for Holmes Bedding. Call 1-800-546-5637 for Holmes Appliances.
Holmes Fan Replacement Parts by Model
eReplacement Parts
https://www.ereplacementparts.com > holmes-fan-parts-...
Shop OEM Holmes Fan parts that fit, straight from the manufacturer. We offer model diagrams, accessories, expert repair help, and fast shipping.
Holmes Replacement Parts ' Fast Shipping at Repair Clinic
Repair Clinic
https://www.repairclinic.com > Shop-For-Parts > Holme...
Find Holmes Replacement Parts at RepairClinic.com. Repair for less! Fast, same day shipping. 365 day right part guaranteed return policy.
Holmes - Heating & Cooling Parts & Accessories ...
Amazon.com
https://www.amazon.com > Heating-Cooling-Parts-Acce...
Online shopping for Home & Kitchen from a great selection of Stove & Fireplace Accessories, Air Conditioner Parts & Accessories, Air Purifier Parts
4/20/2024 12:29:02 AM •
Dryers
Answered
3 days ago
How can I find my necklace in my dryer?
First check the lent catching screen and then the vent and hose and the ground below the vent exit. Completely clean those out. If you don't find the necklace in that process, turn the dryer on to see if it will eject the necklace into the vent hose. If it is trapped behind the drum, you should be able to hear it rattling around. However, dismantling the dryer can be dangerous so you should consider a hiring a dryer repairman to do that if it is necessary.
4/7/2024 3:27:06 AM •
Dryers
Answered
on Apr 07, 2024
Faqe7077kw0 dryer beeps 3 times won't start replaced the door switch same problem. Hold in the select button and press start and it will run until I let up on the select button
- Check the Power Supply:
- Ensure that your dryer is receiving proper power. Use a multimeter to test the wall plug. You should have two poles giving 110-120 volts each and a ground. If only one side is hot and the other is not, you could have issues.
- Common Causes for Dryer Not Starting:
- Let's explore some common reasons why your dryer might not start:
- Thermal Fuse: The thermal fuse is a safety device that protects the dryer from overheating. If it's blown, the dryer won't start. Test it for continuity using a multimeter Check your exhaust vent for restrictions..
- Start Switch: If the dryer hums but doesn't start, the start switch might be faulty. Test it for continuity with a multimeter.
- Door Switch: The door switch activates when the dryer door is closed. Listen for a "click" when you start the dryer. If you don't hear it, test the door switch for continuity.
- Door Switch Solution:
- If the door switch isn't "clicking," it might be the culprit. Try this:
- Push the length of the switch from side to side (without removing it) to see if it clicks.
- If it clicks, it's likely not defective.
- Reassemble the dryer to see if it works.
Remember to
safely disconnect the power before attempting any repairs. If these steps don't resolve the issue, consider seeking professional assistance or further diagnostics
3/13/2024 3:16:44 AM •
Dryers
Answered
on Mar 13, 2024
Cissell dryer not lighting and showing code "af"?
Code af on the cissell commercial dryers is air flow. Check the lint trap and the tube leading outside the most effective way to do this is start the dryer let it heat up and take a hand held digital thermometer and check the tube . You will see a drop in temperature when you pass the blockage . If that's not the issue omh you temp sensor in the lint trap compartment.
3/6/2024 12:13:36 AM •
Dryers
Answered
on Mar 06, 2024
I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
2/20/2024 2:57:13 PM •
Dryers
Answered
on Feb 20, 2024
Broke the light bulb in my dryer off in socket it threw sparks now my dryer won't work. Checked breaker that's not the problem. What could it be?
If the light bulb in your dryer broke off in the socket and caused sparks, it's possible that the electrical system in the dryer has been damaged. Here are some steps you can take to troubleshoot the issue:
1.Start by unplugging the dryer.
2. If there are any broken pieces of the light bulb still in the socket, use needle-nose pliers or another suitable tool to remove them. Be sure to do this with caution to avoid electrical shock.
3. Inspect the area around the light bulb socket for any burnt wires, connectors, or components. If you find any damaged parts, they may need to be replaced.
4. Dryers often have thermal fuses or thermal cut-offs that can blow if there's a surge or overheating. Check the dryer's user manual to locate these components and check if they are intact. If a fuse is blown, replace it with the same type and amperage.
5. Use a multimeter to check the voltage at the dryer outlet. Ensure that you are getting the correct voltage (typically 240 volts for a dryer in the United States). If the voltage is incorrect, there may be an issue with the electrical supply or the outlet itself.
6. If you have the skills and confidence, you may open the dryer cabinet and inspect the internal wiring. Look for any burnt or damaged wires and connections. If you find any, you may need to repair or replace the affected parts.
7. If you are not comfortable or experienced with electrical repairs, it's advisable to seek the help of a professional appliance repair technician. They can thoroughly diagnose the issue and perform any necessary repairs or replacements.
2/4/2024 2:08:18 AM •
Dryers
Answered
on Feb 04, 2024
