20 Most Recent Sears Kenmore Elite 4.2 cu. ft. Front-Load Steam Washer featuring Smart Questions & Answers
Flashes error code f06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
10/20/2012 12:25:27 AM • Sears Kenmore... • Answered on Oct 20, 2012
Kenmore Washer smell like burning rubber
It could be possibly the belt. or if not, possibly a wire grounding out. Most likely the belt. If the motors on a bind or going bad, it can smell like that also
5/27/2014 6:03:45 PM • Sears Dryers • Answered on May 27, 2014
Dryer won't heat
element or stats
4/3/2014 7:42:48 PM • Sears Dryers • Answered on Apr 03, 2014
Sears Kenmore Dryer Model 110.60936990 does not heat.
The heating element is burned out and needs to be replaced
4/3/2014 2:02:54 PM • Sears Dryers • Answered on Apr 03, 2014
Gas dryer timer doesn't shut off
replace timer
11/11/2012 8:19:49 PM • Sears Dryers • Answered on Nov 11, 2012
How can I find my necklace in my dryer?
First check the lent catching screen and then the vent and hose and the ground below the vent exit. Completely clean those out. If you don't find the necklace in that process, turn the dryer on to see if it will eject the necklace into the vent hose. If it is trapped behind the drum, you should be able to hear it rattling around. However, dismantling the dryer can be dangerous so you should consider a hiring a dryer repairman to do that if it is necessary.
4/7/2024 3:27:06 AM • Dryers • Answered on Apr 07, 2024
Oster 12 bottle wine cellar model 0W0912H6H. Not sure what temp it's at. The panel out but not cooling.
Get rid of it. The problem is likely the control board. Open this page, press CTRL+F and type 0W0912H6H and press enter. Full of issues! https://www.consumeraffairs.com/homeowners/oster_appliances.html?page=3 https://www.google.com/search?q=Oster+0W0912H6H+problems+with+display+panel ..
4/2/2024 4:41:00 AM • Dryers • Answered on Apr 02, 2024
2answers
New defy tumble dryer dtd259 dried 1 bundle of washing and now bottom light of time remaining indicator stays on. Refuse to reset or even after unplugging for few minutes still doing it.
I've just browsed your hand book that goes with this machine, as I'm in the UK I can sumise from the booklet that this won't reset as the fluff filter has something obtrusive in it, or there is something caught in the tube venter grille, can I suggest if both those are clear you hold the cancel/reset button down for a few seconds to reset & reboot it into ready mode, sorry I can't be of more help than this ????
3/22/2024 10:23:55 AM • Dryers • Answered on Mar 22, 2024
I cleaned the blades on my Ionic Pro Air Filter 2 times, then vacuumed the slots on the vent. It is still buzzing when I turn it on.
2xs and 2x's is 2 extra small in clothes and not the same as '2 times'. Edited out for clarity. If the fan isn't turning, either the run capacitor has failed or the fan is binding. If the fan is turning is is part of the ionization process or there is a bad connection. What the maker says Noisy functioning (audible loud buzzing sound) is a sign that your Ionic Pro® Compact ionic air purifier is overdue for a complete clean-up of the collection blades and the internal ionizing wires. The internal ionizing wires must be kept clean to ensure silent and normal operation. May 10, 2011
Or it is just worn out! https://www.google.com/search?q=ionic+pro+air+purifier+buzzing+noise ..
3/20/2024 6:11:51 AM • Dryers • Answered on Mar 20, 2024
I need a manual for Harbor Breeze ceiling fan model #LP8293LBN
Good luck! That's just a low-end store brand for Lowes.
3/13/2024 10:22:12 AM • Dryers • Answered on Mar 13, 2024
Faqe7077kw0 dryer beeps 3 times won't start replaced the door switch same problem. Hold in the select button and press start and it will run until I let up on the select button
  1. Check the Power Supply:
    • Ensure that your dryer is receiving proper power. Use a multimeter to test the wall plug. You should have two poles giving 110-120 volts each and a ground. If only one side is hot and the other is not, you could have issues.
  2. Common Causes for Dryer Not Starting:
    • Let's explore some common reasons why your dryer might not start:
      • Thermal Fuse: The thermal fuse is a safety device that protects the dryer from overheating. If it's blown, the dryer won't start. Test it for continuity using a multimeter Check your exhaust vent for restrictions..
      • Start Switch: If the dryer hums but doesn't start, the start switch might be faulty. Test it for continuity with a multimeter.
      • Door Switch: The door switch activates when the dryer door is closed. Listen for a "click" when you start the dryer. If you don't hear it, test the door switch for continuity.
  3. Door Switch Solution:
    • If the door switch isn't "clicking," it might be the culprit. Try this:
      • Push the length of the switch from side to side (without removing it) to see if it clicks.
      • If it clicks, it's likely not defective.
      • Reassemble the dryer to see if it works.
Remember to safely disconnect the power before attempting any repairs. If these steps don't resolve the issue, consider seeking professional assistance or further diagnostics
3/13/2024 3:16:44 AM • Dryers • Answered on Mar 13, 2024
2answers
Are harbor breeze light kits universal to all harbor breeze fans?
For information on Harbor Breeze light kits you will need to check the model number and consult the manual. Do you know the model name and number? If you do you can check for the manual here on Harbor Breeze Ceiling Fan Manuals I found the articles on Harbor Breeze Accessories helpful for solving remote control problems. There is also a great deal of information on Harbor Breeze helpful for solving remote control problems and many other issues involving your Harbor Breeze Ceiling Fan. Hope this all helps
3/7/2024 12:12:54 PM • Dryers • Answered on Mar 07, 2024
Cissell dryer not lighting and showing code "af"?
Code af on the cissell commercial dryers is air flow. Check the lint trap and the tube leading outside the most effective way to do this is start the dryer let it heat up and take a hand held digital thermometer and check the tube . You will see a drop in temperature when you pass the blockage . If that's not the issue omh you temp sensor in the lint trap compartment.
3/6/2024 12:13:36 AM • Dryers • Answered on Mar 06, 2024
Gassy smell from Electrolux electric dryer
Sounds like you have a blockage somewhere. There may be an animal or a bird's nest in there. Dryers should be fully stripped and cleaned about every 3 years. 'Dryer Fires' are a real thing and there are companies that do nothing except clean and de-lint dryers. https://www.google.com/search?q=Dryer+Fires ..
2/23/2024 8:24:00 PM • Dryers • Answered on Feb 23, 2024
3answers
I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
2/20/2024 2:57:13 PM • Dryers • Answered on Feb 20, 2024
3answers
How to Operate an AC-552 ceiling fan?
Do you have the owners manual? It has a lot of troubleshooting tips. You can also check out this article for the Hampton Bay AC 552 Ceiling Fan https://hamptonlightingadvice.com/ac-552-ceiling-fan-manual-parts-remote/ This video might help as well
2/19/2024 1:53:32 PM • Dryers • Answered on Feb 19, 2024
3answers
My Baumatic oven model POP9030SS is displaying error F4E0 every time it's switched on.
If the trip blows as you switvh on the oven, it is the oven element. If your oven is a fan assisted oven, check the fan element first.
2/10/2024 1:01:31 PM • Dryers • Answered on Feb 10, 2024
Broke the light bulb in my dryer off in socket it threw sparks now my dryer won't work. Checked breaker that's not the problem. What could it be?
If the light bulb in your dryer broke off in the socket and caused sparks, it's possible that the electrical system in the dryer has been damaged. Here are some steps you can take to troubleshoot the issue: 1.Start by unplugging the dryer. 2. If there are any broken pieces of the light bulb still in the socket, use needle-nose pliers or another suitable tool to remove them. Be sure to do this with caution to avoid electrical shock. 3. Inspect the area around the light bulb socket for any burnt wires, connectors, or components. If you find any damaged parts, they may need to be replaced. 4. Dryers often have thermal fuses or thermal cut-offs that can blow if there's a surge or overheating. Check the dryer's user manual to locate these components and check if they are intact. If a fuse is blown, replace it with the same type and amperage. 5. Use a multimeter to check the voltage at the dryer outlet. Ensure that you are getting the correct voltage (typically 240 volts for a dryer in the United States). If the voltage is incorrect, there may be an issue with the electrical supply or the outlet itself. 6. If you have the skills and confidence, you may open the dryer cabinet and inspect the internal wiring. Look for any burnt or damaged wires and connections. If you find any, you may need to repair or replace the affected parts. 7. If you are not comfortable or experienced with electrical repairs, it's advisable to seek the help of a professional appliance repair technician. They can thoroughly diagnose the issue and perform any necessary repairs or replacements.
2/4/2024 2:08:18 AM • Dryers • Answered on Feb 04, 2024
Sears Kenmore Elite 4.2 cu. ft. Front-Load Steam Washer featuring Smart Logo
8 questions posted
Top Sears Dryers Experts
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Sears Dryer Expert? Answer questions, earn points and help others
View Most Popular
Sears Dryers
  • Sears Dryers
Most Popular Question
flashes error code f06
  • Dryers
