20 Most Recent Kalorik STP-20159 1350-Watt 22-inch Digital Fabric Steam Press Questions & Answers
0answers
My Laura star iron is continuously steaming and won't stop My Laura star iron is continuously steaming and won't stop
The steam valve may be partially blocked with scale so it doesn't close properly. You can try disconnecting the iron from the base unit and flushing it several times with the valve open and then closed. If it is possible to disassemble the valve, you can clean the contamination directly. You may also find that the seal or o-ring is worn out. My mother would use only distilled water in her iron, so she never had that problem. I see from the product manual* that yours is "designed for use with tap water" if the filter is used. There's probably a limit to how much lime in the water it will tolerate, but the manual says nothing about that. If the Laurastar Lift Xtra is less than a year old and you were diligent about replacing the filter when you got the replacement alert light, you may be able to get warranty service. *http://image.email.laurastar.com/lib/fe4715707564057e751572/m/3/75bb559a-f7e0-4d65-aa02-6d2bf912641f.pdf
2/24/2024 8:19:17 PM • Irons • Answered on Feb 24, 2024
ELITECH 2400W CERAMIC SOLEPLATE STEAM GENERATOR IRON where can i get a replacement water filter from i cant find it any were on the net please help
Finding replacement parts for specific products can sometimes be challenging, especially if they are not readily available online. Here are some steps you can take to locate a replacement water filter for your Elitech 2400W Ceramic Soleplate Steam Generator Iron:
  1. Contact the Manufacturer: Start by reaching out to the manufacturer of the steam generator iron. They may have spare parts available for purchase or be able to direct you to authorized retailers or distributors who carry replacement water filters.
  2. Check Online Marketplaces: While you mentioned that you couldn't find the water filter online, it's worth checking popular online marketplaces like Amazon, eBay, or Alibaba. Sellers on these platforms often offer a wide range of replacement parts for various appliances.
  3. Visit Local Retailers: Visit local appliance stores or retailers that specialize in household appliances. They may carry replacement parts for steam generator irons or be able to place a special order for the water filter on your behalf.
  4. Search Specific Parts Retailers: Look for retailers that specialize in selling replacement parts for appliances. These retailers may have a wider selection of parts available and could potentially have the water filter you need.
  5. Consider Universal Filters: If you're unable to find an exact replacement water filter for your specific model, consider looking for universal water filters that are compatible with steam generator irons. While they may not be an exact match, they could still work effectively.
  6. Join Online Forums or Communities: Join online forums or communities dedicated to appliance repair or steam generator irons. Members of these communities may have tips or suggestions on where to find replacement parts or may be willing to sell or trade spare parts.
  7. Check with Local Repair Shops: Reach out to local appliance repair shops or service centers. They may have access to a network of suppliers or be able to source the replacement water filter for you.
2/23/2024 6:22:53 PM • Irons • Answered on Feb 23, 2024
My D2030 iron does not heat up the power light and the screen light come on but does not heat up
1...You need to check the iron settings as they have an adjustable knob that controls temperature as well as governs which kind of materials you want to iron. Different clothing materials need different temperature and other settings. Make sure you set the knob carefully. If you are unable to set the knob properly, you can check the user manual and make sure the temperature or heat amount is set at the right point.
2...Another thing that you need to check in order to inspect why the iron press is not heating up is the water reservoir. In some cases, if the water reservoir is empty then the iron press may not be heating up as much as it should.
For this, switch the iron off and make sure it is cool. Switch it on again and top up the water in the reservoir. Now try ironing again to see whether the heat is proper or not.
3....Another thing that you need to check in order to inspect why the iron press is not heating up is the water reservoir. In some cases, if the water reservoir is empty then the iron press may not be heating up as much as it should.
2/14/2024 6:37:11 AM • Irons • Answered on Feb 14, 2024
Elna Press 2000 Ironing Press. Why won't my press close?
Question edited for clarity. Question moved from Elna Sewing Machines No one has reported this issues, so there are no known fixes. The system is simple, just a hinge with a spring to counterbalance some of the weight. Look for something out of place or binding at the hinge area, perhaps the pivot pin is dislodged. https://www.google.com/search?q=elnapress+iron+won%27t+close+properly ..
2/9/2024 7:02:15 PM • Irons • Answered on Feb 09, 2024
My iron is not warm up
please check the pilot lamp is on and lighting, if not, replace the fuse in the wire cod. also check on the internal thermal fuse it might be damaged. if all fuses are fine please measure the resistance of the heating element and verify that the switch is closing properly
2/5/2024 8:17:17 PM • Irons • Answered on Feb 05, 2024
My Phillips 8500 steam generator works but makes a constant clicking sound.
please check the distance between the live and earth surface of the flat iron. the clicking sound could be originating from a possible short circuit
2/5/2024 8:11:39 PM • Irons • Answered on Feb 05, 2024
Hinari hin172 steam iron won't stop steaming
1/4/2024 2:38:48 PM • Irons • Answered on Jan 04, 2024
Tobi Platinum Model EC1710 Garment Steamer. It does not make steam, It is on but doesn't make steam. Poured vinegar in the water tank.
Question edited for clarity and all the typos / spelling errors. Descale it again, but use CLR Descaler which is made for the job. I presume you can feel heat? When using the descaler shake the unit every 5 minutes because the steam valve outlet will be at the top. of the heater chamber. https://www.google.com/search?q=Tobi+Platinum+Model+EC1710+descale Use the mix details for Irons and coffee machines
CLR Calcium, Lime and Rust Remover
CLR Brands https://clrbrands.com > Products > CLR-Household Get rid of stubborn lime, calcium, and rust stains effortlessly with our powerful all-in-one cleaner. Visit CLR Brands now for sparkling, spotless surfaces. ..
12/28/2023 2:26:33 AM • Irons • Answered on Dec 28, 2023
Do I need to empty the steam tube at the end of ironing
Heating elements are vulnerable, they have a filament. Heat being generated should freely disperse. Another reason for having the water tank connected, is the possible buildup of scale. Like with coffee makers, the temperature would not reach a high enough level after some time and the iron then requires descaling.
10/25/2023 4:08:58 PM • Irons • Answered on Oct 25, 2023
2answers
Can't unscrew the boiler screw
My anti calc stick is stuck in the iron and the pink holder is broken what do i do
8/27/2023 8:44:03 AM • Irons • Answered on Aug 27, 2023
Iron drips water while ironing. Sometimes it rusty
Use filtered water in the iron if your tap water is exceptionally hard or includes a lot of minerals. This can lessen the likelihood of corrosion and mineral development.
8/14/2023 7:14:21 AM • Irons • Answered on Aug 14, 2023
I've been given a Tefal Pro Express Care Iron but I can't remove the Anti-Calc collector.
Question edited for clarity, it is a 'Tefal' not a 'teal pro'. If it breaks, you can buy another, but descale the inside with CLR or a proper descaling solution.
Calc Collector Tefal Pro Total Express Steam Iron Anti ...
Part Seeker https://www.partseeker.co.uk > Shop Calc Collector Tefal Pro Total Express Steam Iron Anti Limescale Cap Remover - 144190 ... Genuine Tefal replacement removable anti calc lime scale collector ... £13.99 · ‎In stock ..
7/25/2023 1:29:04 PM • Irons • Answered on Jul 25, 2023
My eurosteam duet does not heat but the steam pump works and spits out water
If your Eurosteam Duet is not heating up and there is no steam being produced despite the water pump functioning properly, it suggests there may be an issue with the heating element or the temperature control system. Here are a few troubleshooting steps you can try:
  1. Check the power source: Ensure that the iron is plugged into a functioning power outlet and that the power cord is securely connected to the iron. You can try plugging the iron into a different outlet to rule out any issues with the power source.
  2. Inspect the heating element: The heating element is responsible for generating the heat required for steam production. Over time, it can become damaged or worn out. If you are comfortable with electronics, you can use a multimeter to test the continuity of the heating element. If the heating element is faulty, it may need to be replaced by a qualified technician.
  3. Clean the iron: Sometimes, mineral deposits or limescale buildup can affect the heating performance of the iron. Try cleaning the iron according to the manufacturer's instructions. This usually involves using a descaling solution or vinegar to remove any mineral deposits from the internal components. Follow the instructions carefully to avoid damaging the iron.
  4. Check the temperature control system: The temperature control system regulates the heat output of the iron. If it is malfunctioning, it can prevent the iron from reaching the desired temperature. Unfortunately, diagnosing and repairing the temperature control system usually requires professional expertise. Consider contacting the manufacturer's customer support or a professional appliance repair service for assistance.
6/18/2023 5:29:52 PM • Irons • Answered on Jun 18, 2023
3answers
Iron keeps blowing trip when turned on
For more info about Iron keeps blowing trip when turned on: Dial 1 844 441 2440 for free Garmin map update technical support
6/12/2023 2:02:28 PM • Irons • Answered on Jun 12, 2023
The steam is coming out but no pressure when I press the button for the steam to jet out
If you're experiencing an issue where steam is coming out but there's no pressure when you press the button for the steam to jet out, there could be a few possible causes:
  1. Water level: Check the water level in the steam generator or steam-producing device. If the water level is too low, it can result in insufficient steam pressure. Make sure there is enough water in the device according to the manufacturer's instructions.
  2. Clogged steam vents: Over time, mineral deposits or debris can accumulate in the steam vents, obstructing the flow of steam. This can prevent the steam from building up pressure. Clean the steam vents thoroughly by following the manufacturer's instructions to ensure proper steam flow.
  3. Faulty heating element: The heating element is responsible for generating steam. If it is malfunctioning or damaged, it may not produce enough heat to generate adequate pressure. In this case, you may need to have the heating element inspected or replaced by a professional.
  4. Malfunctioning steam generator: If you're using a steam generator, it's possible that there is an issue with the device itself. Check for any error codes or warning indicators and consult the manufacturer's troubleshooting guide. If the problem persists, contact the manufacturer or a qualified technician for assistance.
  5. Incorrect settings: Ensure that you have selected the appropriate steam settings
5/20/2023 12:31:11 PM • Irons • Answered on May 20, 2023
Kalorik STP-20159 1350-Watt 22-inch Digital Fabric Steam Press Logo
1 questions posted
Top Kalorik Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Kalorik Iron Expert? Answer questions, earn points and help others
View Most Popular
Kalorik Irons
  • Kalorik Irons
Most Popular Question
panasonic cordless 360 freestyle iron ni
  • Irons
