20 Most Recent Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W Questions & Answers
Mains lead replacement
To disassemble the Russell Hobbs 15081steam glide iron, you have to remove the two hidden screws on the handle. To locate the first screw remove the two adjacent blue buttons which are each held in with two hidden clips front and rear, so lever out with small screwdriver or similar. The second hidden screw is under the pivots of the water inlet lid.(I broke one of the plastic pivots but no big deal). Then using a thin blade, separate the top half of the handle from the bottom half of the handle. A bit of force is needed as there are more plastic clips. I started from the rear. Once the top half the handle is removed, other screws become visible, so teardown is not hard, just note which screws go where, as they are different lengths. My problem was that some of the screws/bolts were so corroded I needed to drill them out. The thermostat was also corroded, which probably explained why the thermal fuse had blown. The element was fine.
3/4/2019 8:01:55 PM • Russell Hobbs... • Answered on Mar 04, 2019
0answers
0answers
2answers
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
12/17/2023 3:33:21 PM • Russell Hobbs... • Answered on Dec 17, 2023
2answers
My Russell Hobbs smart glide iron as stopped releasing steam can you help
When on iron iron get heated up the tank also heated up but water is not being sucked my machine from water compartment no voice or sound is heard to pump in water to make steam
12/17/2023 1:21:19 PM • Russell Hobbs... • Answered on Dec 17, 2023
Russell Hobbs steam iron 24420 I have replaced the cartridge as the steam stoped coming through now water is leaking from underneath the base unit?
check cartridge is positioned, aligned, and secured in place correctly. It could cause leaking if it is not placed correctly.
8/14/2023 7:00:12 AM • Russell Hobbs... • Answered on Aug 14, 2023
How to dismantle a russell hobbs steamglide iron
To disassemble the Russell Hobbs 15081 steam glide iron, you have to remove the two hidden screws on the handle. To locate the first screw remove the two adjacent blue buttons which are each held in with two hidden clips front and rear, so lever out with small screwdriver or similar. The second hidden screw is under the pivots of the water inlet lid.(I broke one of the plastic pivots but no big deal). Then using a thin blade, separate the top half of the handle from the bottom half of the handle. A bit of force is needed as there are more plastic clips. I started from the rear. Once the top half the handle is removed, other screws become visible, so teardown is not hard, just note which screws go where, as they are different lengths. My problem was that some of the screws/bolts were so corroded I needed to drill them out. The thermostat was also corroded, which probably explained why the thermal fuse had blown. The element was fine.
10/23/2021 5:55:05 PM • Russell Hobbs... • Answered on Oct 23, 2021
Hi. I have Russell Hobbs iron not getting hot but the power light is coming on but the iron not getting hot
Check may be the wire cable is cut off inside or cut off from the iron.. Be careful it could be bridging issue or the elements are no more in contact get in touch with the repairers
7/12/2019 10:53:41 AM • Russell Hobbs... • Answered on Jul 12, 2019
Russell Hobbs steam iron RHI613 Had it for two years One day it was still working fine the next day it was not working anymore The plug is fine How do I open the iron?
don't bother it is not repairable and you are not an electrician junk it and get an updated version with warranty
5/4/2018 9:46:45 AM • Russell Hobbs... • Answered on May 04, 2018
I have a Russell Hobbs easyfill 2400W Iron. Water is running out the base of the iron. How can this be rectified?
take it in to an appliance repair shop generally it is cheaper to junk it and get a better quality unit
12/21/2017 9:25:03 AM • Russell Hobbs... • Answered on Dec 21, 2017
Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W Logo
8 questions posted
Top Russell Hobbs Irons Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
View Most Popular
Russell Hobbs Irons
  • Russell Hobbs Irons
Most Popular Question
mains lead replacement
  • Irons
