20 Most Recent
Holmes HM-7204 Cool Mist Humidifier Filter HWF100 Questions & Answers
Why does my Aprilaire humidifier gurgle?
Mine was doing the same thing...first month of operation (installed toward end of heating season) = no problems with noise (bubbling, gurgling) though the duct work - started second year toward middle of season. Now its been running for a few weeks and is intolerable. I dug out owners manual and it did not address this at all. I dug out the installation manual and viola! Gurgling is caused by excess condensation in the steam hose. Sure enough the steam hose had a small area depression and did NOT have the constant downward slope necessary - installation instructions are VERY specific about needing a slope in order to allow condense to drain from the steam house. The zip-tie installation had slide down from a vertical stabilizing pipe & allowed for the hose to sag in the middle (nice install job slacker). I adjusted it and the SOUND IS GONE. Hope this helps someone else.
1/27/2024 8:11:06 PM •
Humidifiers
Answered
on Jan 27, 2024
I can't get my humidifier to get the humidity to get over 17% and the dial is set at 30% it goes to 20% and flashes
Without brand and model, my advice is definitely a shot in the dark. Only your manual or your manufacturer's site can inform you of what the flashing means.
Here are some tips that might help you increase the humidity in your room:
Check the humidifier's water level: Make sure that the humidifier has enough water to function properly. If the water level is low, the humidifier may not be able to produce enough moisture to increase the humidity in the room.
Clean the humidifier: Over time, mineral deposits and bacteria can build up in the humidifier, which can affect its performance. Clean the humidifier regularly according to the manufacturer's instructions.
Place the humidifier in the right location: Place the humidifier in a central location in the room, away from walls and other obstructions. This will help the humidifier distribute moisture evenly throughout the room.
Use a humidistat: A humidistat is a device that measures the humidity in the room and automatically adjusts the humidifier's output to maintain a desired humidity level. If your humidifier does not have a built-in humidistat, you can purchase a separate one and use it to control the humidity level in the room.
1/19/2024 4:21:25 AM •
Humidifiers
Answered
on Jan 19, 2024
Elektra humidifier has a flashing water warning sign
Is this a mist generator with an ultrasonic element, popular for "health?"
These have a wick and water is not going trough the dry wick by itself. One should make all of the wick wet, from bottom to top. After that the water keeps being taken up to the element until the device is stored and the wick dries out again. Another thought is that these ultrasonic elements are very similar to a buzzer, like in toys. Two round sheets of metal with plastic in between. This is not like having long lifetime. For expensive mist makers you could perhaps order a new element but I do not have high hopes. Being so vulnerable the humidifiers are shipped containing no water. It is important to rest the top of the wick in water also. Just making the wick wet close to the element does not help or gives bad results.
11/19/2023 4:04:59 AM •
Humidifiers
Answered
on Nov 19, 2023
HumiHumidifier was running. because water level was level I filled as usual. now it doesn't run.that's the problem.Pleas help
There could be several reasons why a humidifier stops running after refilling it with water. One of the most common reasons is that the humidifier's float switch is stuck in the "low water" position, which prevents the humidifier from turning on even after refilling it with water . Another reason could be that the humidifier's water level sensor is malfunctioning, which causes the humidifier to stop running even when there is enough water in the tank/
If you have a whole-house humidifier, it could be that the humidistat is set too low, which causes the humidifier to turn off even when there is enough water in the tank 1. Alternatively, if you have a portable humidifier, it could be that the unit's motor has burned out or that its fan has stopped working .
To troubleshoot this issue, you can try cleaning the float switch or replacing the water level sensor if they are damaged. If you have a whole-house humidifier, you can try adjusting the humidistat to a higher setting. If you have a portable humidifier, you can try replacing its motor or fan
10/15/2023 1:13:24 AM •
Humidifiers
Answered
on Oct 15, 2023
The humidifier was running.Because water lecel was low. I filled it as usual. Now it doesn't run. Why
10/15/2023 1:12:26 AM •
Humidifiers
Answered
on Oct 15, 2023
Where to download Panasonic air purifier with humidifier F-VXT70 user manual
Sure, here's the user manual for the Panasonic air purifier with humidifier F-VXT70:
Introduction: Thank you for purchasing the Panasonic air purifier with humidifier F-VXT70. This unit combines a powerful air purifying function with a high-performance humidifying function to provide you with clean and comfortable air.
Safety precautions: Please read and follow all safety precautions before using this product.
- This product is for indoor use only.
- Do not use this product for any purpose other than its intended use.
- Do not disassemble or modify this product.
- Keep this product out of reach of children and pets.
- Unplug this product before cleaning or maintaining it.
- Do not use this product near water.
- Do not use this product with a damaged power cord.
- Do not use this product if it has been dropped or damaged.
- Use only the power cord provided with this product.
Operating instructions:
- Place the unit in a stable location near a power outlet.
- Open the water tank cover and fill the tank with clean water up to the MAX line.
- Close the water tank cover and plug in the power cord.
- Press the power button to turn on the unit. The air purifying and humidifying functions will start automatically.
- Use the mode button to select the desired mode:
- Auto mode: The unit will automatically adjust its operation based on the air quality and humidity level.
- Manual mode: You can adjust the fan speed and humidity level manually.
- Use the fan speed button to adjust the fan speed in manual mode.
- Use the humidity level button to adjust the humidity level in manual mode.
- When the water in the tank runs out, the unit will automatically stop the humidifying function. You can refill the tank and resume operation by pressing the power button again.
- Clean the unit regularly according to the maintenance instructions in the user manual.
Maintenance instructions:
- Unplug the power cord and empty the water tank before cleaning the unit.
- Use a soft cloth to wipe the exterior of the unit.
- Remove the filter and wash it with water. Allow it to dry completely before reinstalling it.
- Clean the water tank with a soft brush and mild detergent. Rinse thoroughly and allow it to dry completely before refilling it.
- Clean the humidifying unit with a soft brush and mild detergent. Rinse thoroughly and allow it to dry completely before reinstalling it.
- Reassemble the unit and plug in the power cord.
Troubleshooting: If the unit does not operate properly, try the following solutions:
- Make sure the power cord is securely plugged into the power outlet.
- Check the water tank and refill it if necessary.
- Clean the filter, water tank, and humidifying unit according to the maintenance instructions.
- Contact the customer service center if the problem persists.
3/8/2023 6:13:53 AM •
Humidifiers
Answered
on Mar 08, 2023
How to fill Air Innovation humidifier water tank model A1-KS30U-06C
Here are the steps to fill the water tank of the Air Innovation humidifier model A1-KS30U-06C:
- Turn off the humidifier and unplug it from the power source.
- Remove the water tank from the base of the humidifier by lifting it straight up.
- Flip the water tank over and unscrew the cap from the bottom of the tank in a counterclockwise direction.
- Fill the tank with clean, cool water. Do not overfill the tank; leave some space at the top to prevent spills.
- Screw the cap back onto the bottom of the tank in a clockwise direction until it is snug.
- Turn the water tank right side up and carefully place it back onto the base of the humidifier. Make sure it is seated properly and securely.
- Plug the humidifier back in and turn it on.
Once the tank is filled with water, the humidifier should operate normally and begin adding moisture to the air. It is recommended to clean the water tank periodically to prevent buildup of mineral deposits and bacteria.
2/28/2023 6:27:55 AM •
Humidifiers
Answered
on Feb 28, 2023
Mainstays Cool Mist Humidifier 1 gal MDH-0103JW Low Tank Indicator Auto Off NEW Manual
Here are the instructions for the Mainstays Cool Mist Humidifier 1 gal MDH-0103JW:
- Remove the water tank by lifting it straight up and off the base.
- Turn the water tank over and remove the tank cap by turning it counterclockwise.
- Fill the tank with cool water and replace the cap by turning it clockwise.
- Place the tank back onto the base, making sure it is seated securely.
- Plug the humidifier into an electrical outlet.
- Press the power button to turn on the humidifier. The power light will illuminate.
- Press the mist button to select the desired mist output level.
- The humidifier will automatically shut off when the water level in the tank is low.
- To refill the tank, repeat steps 1-4.
Note: For optimal performance, it is recommended to clean the humidifier weekly. Please refer to the user manual for detailed cleaning instructions.
2/26/2023 10:36:57 AM •
Humidifiers
Answered
on Feb 26, 2023
Essick D46720 water overflows from water holding well
If the water overflows from the water holding well in your Essick D46720 humidifier, there could be a few possible reasons:
- Faulty Float Valve: The float valve regulates the water level in the holding well. If it gets stuck or fails to function properly, it can cause the water to overflow. You can try cleaning the float valve and make sure it moves freely.
- Clogged Water Inlet: Check the water inlet on the bottom of the humidifier. If it is clogged with mineral deposits or other debris, it can prevent the water from flowing into the holding well at the proper rate.
- Broken Water Tank: If the water tank is cracked or damaged, it can cause water to leak out of the holding well and overflow.
- Incorrect Water Level: If you are filling the humidifier beyond the recommended water level, it can cause the water to overflow.
To fix the issue, try the following steps:
- Turn off and unplug the humidifier.
- Remove the water tank and check for cracks or damages.
- Clean the float valve and make sure it moves freely.
- Check the water inlet for any clogs or debris.
- Make sure you are filling the humidifier with the correct amount of water, as recommended in the user manual.
- Plug in the humidifier and turn it on to see if the issue is resolved.
If the problem persists, you may need to contact the manufacturer for further assistance or consider replacing the humidifier.
2/26/2023 9:46:43 AM •
Humidifiers
Answered
on Feb 26, 2023
