20 Most Recent
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Questions & Answers
We had a fire at work and lost my power cable (I
If you can't find a cord, you can just take the drive out of the case & install it in your desktop as a 2nd drive. That way you can get to your files. Also, they make a adapter cable to make it a USB drive, you could try that.
6/27/2014 3:47:49 PM •
Acomdata...
Answered
on Jun 27, 2014
My hard drive is blinking
If this is an USB external hard drive the try connecting it to another computer.If it does not work then the hard drive is faulty. All hard drives will eventually fail. There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
3/30/2013 5:40:08 AM •
Acomdata...
Answered
on Mar 30, 2013
Need driver
if you have the external hard drive , just plug it into the usb port then access the drive , they comes preformated
2/7/2013 1:31:02 PM •
Acomdata...
Answered
on Feb 07, 2013
Hard drive clicks won't turn
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death". There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
10/21/2012 8:22:31 PM •
Acomdata...
Answered
on Oct 21, 2012
My acomdata hd appears on my desktop then disappears. A red light comes on in the drive
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
4/14/2012 3:15:54 PM •
Acomdata...
Answered
on Apr 14, 2012
