20 Most Recent Dyson DC39 Multi floor canister vacuum cleaner Questions & Answers
Turbo head has stopped spinning
Hi Fay, it's Jack at Dyson. If your DC39 Multi Floor's turbine head has stopped spinning, this could mean there's a blockage in the turbine head, wand, hose or lower duct hose. This could reduce the airflow passing through the machine, which in turn will affect the turbine which powers the rotating brush bar. It's also a good idea to check the Turbine head is free of any threads, hair or other obstructions: turbo-head-stopped-spinning-yb2iqq4t3gdfozzh4fdwdnjv-3-0.jpg If you need further help once you've given this a go, you can reach our experts at the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
3/9/2016 12:40:19 PM • Dyson DC39 Multi... • Answered on Mar 09, 2016
The roller stops as soon as machine turns on, then air leaks with poor suction. How do I fix it?
Hi there, it's Jack at Dyson. I'm sorry to hear you're having difficulty with your DC39 Multi Floor, but from what you've described it sounds like your machine may have a blockage in the floor tool, wand, hose or inlet duct. This is simple to resolve by following each of the steps shown in our video guide: If you continue to have issues with the suction performance or the brush bar in the Triggerhead floor tool after checking for and removing any obstructions, our experts are on hand to help you further. You can reach the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
4/15/2015 1:27:40 PM • Dyson DC39 Multi... • Answered on Apr 15, 2015
How is the dirt canister removed from the Dyson
I'm sure you've figured it out by now but there is a button located next to the handle of the canister and you simply click there to release it.Hopefully that helped!Longmont Epoxy Garage Floors
2/2/2015 9:53:30 PM • Dyson DC39 Multi... • Answered on Feb 02, 2015
HOW TO CLEAN A DYSON DC39 CANISTER VACUUM?
Hi there, it's Jack at Dyson. I'm sure we can help with some advice on cleaning and maintaining your DC39, but can you please confirm if there's a specific part of the machine you need help cleaning? The advice will differ according to which part of the vacuum you're concerned about. Alternatively, you're welcome to call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
10/2/2014 1:15:05 PM • Dyson DC39 Multi... • Answered on Oct 02, 2014
I received my dyson a few months ago. I have used
Hi Joanne, it's Jack at Dyson. I'm sorry to hear you're having difficulty with your DC39 Multi Floor. If the brush bar only seems to be working intermittently, we should be able to help - and if a replacement part is needed we can confirm if this is covered under our 5-year warranty. When you have your machine easily to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to hearing from you.
3/11/2014 8:03:48 PM • Dyson DC39 Multi... • Answered on Mar 11, 2014
Dyson Animal V6 flashing blue and red?
two faults, mainly battery. A flashing blue light indicates that there is no power, please charge the battery. A flashing amber light indicates that there is no power or a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, please call the Dyson Helpline.
Support and How to Guides for your Dyson V6™ Vacuum
3/19/2024 2:47:52 AM • Dyson Vacuums • Answered on Mar 19, 2024
2answers
Dyson DC41
12/31/2023 6:14:55 PM • Dyson Vacuums • Answered on Dec 31, 2023
Is the base of a Dyson AM05 the same as a Dyson AM09?
Question edited for clarity. No it is taller https://www.google.com/search?q=dyson+am05+vs+dyson+am09 ..
12/29/2023 5:30:50 AM • Dyson Vacuums • Answered on Dec 29, 2023
The bottom of the clear canister opens before I am ready...have to re-vacuum. Lock not working correctly. Seems secure when attaching & vacuuming...just falls open before I can remove it.
Check for dirt in tracks of closure mechanism, clean as nessary. Also, check worn mis-aligned, adjusted clasp.
8/17/2023 5:30:43 AM • Dyson Vacuums • Answered on Aug 17, 2023
How to fix the Dyson dc21 motorhead
6/22/2023 11:22:43 AM • Dyson Vacuums • Answered on Jun 22, 2023
Dyson airwrap hair styler turns off at some heat settings and red light is blinking
If your Dyson Airwrap hair styler is turning off at certain heat settings and the red light is blinking, it could indicate a potential issue with the device. Here are a few troubleshooting steps you can try: 1. Check the power supply: Ensure that the Airwrap is properly plugged into a functioning power outlet and that the power cable is securely connected to the device. 2. Reset the device: Unplug the Airwrap from the power source and wait for about 30 seconds. Then, plug it back in and try turning it on again. This reset may resolve any temporary issues. 3. Clean the filter: The Airwrap has a filter located near the base of the handle. Check if the filter is clogged with dust or debris. If so, gently clean it with a soft brush or by rinsing it under running water. Allow it to dry completely before reinserting it into the device. 4. Check for overheating: The red blinking light on the Airwrap can also indicate that the device has overheated. If this is the case, it may have an automatic shut-off feature to protect against damage. Allow the Airwrap to cool down for a while before using it again. Make sure the vents on the device are clear and not blocked by hair or other obstructions. 5. Contact Dyson support: If the issue persists after trying the above steps, it's recommended to contact Dyson customer support for further assistance. They can provide specific troubleshooting advice or arrange for repairs if necessary. Remember to refer to the user manual or Dyson's official support channels for the most accurate and up-to-date information regarding your specific model of the Dyson Airwrap hair styler.
6/21/2023 9:21:46 AM • Dyson Vacuums • Answered on Jun 21, 2023
My Dyson n AM09 keeps flashing red light and shows 42
The Dyson support site has choices of visible issues about led staying on, letters f, c, h showing, or many other options
https://www.dyson.com/support/journey/troubleshooting/61874-01/visible-issue-243255
6/12/2023 3:30:24 AM • Dyson Vacuums • Answered on Jun 12, 2023
I purchased a genuine Dyson bin replacement and when I try to shut the bin lid after I put the new one in it won't close.
Where did you order the 'Genuine Part' from. It sounds like a Genuine copy made in China like the brush that was sent to me. Genuine parts only come from Dyson direct. Mine came from Amazon. https://www.google.com/search?q=genuine+dyson+bin+replacement ..
3/14/2023 4:57:46 AM • Dyson Vacuums • Answered on Mar 14, 2023
Broken latch on Dyson dc77/up14
1/23/2023 11:43:52 PM • Dyson Vacuums • Answered on Jan 23, 2023
On my dyson 02-89666B. The power head keeps shutting off when I go to vacuum. When its not flat on the floor it works
If the vacuum cleaner's airways become blocked, the device will automatically shut off to prevent damage. Check for blockage at the power head. It probably runs when not flat because it can suck air past the blockage. If the vacuum's filter is full of debris, the vacuum may lose suction, causing the device to turn off automatically...which I doubt in your case. Be cautious removing the blockage for sharp objects. Best to you
1/23/2023 8:19:56 PM • Dyson Vacuums • Answered on Jan 23, 2023
Dyson DC39 Multi floor canister vacuum cleaner Logo
Popular Tags
9 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
turbo head stopped spinning
  • Vacuums
