20 Most Recent DBX -215 Home Equalizer Questions & Answers
2answers
File in Outbox cannot delete or send
>lets go store location
>open outlook express>tools>options>maintenance>store folder>Copy the location
>click start >run>paste the location >Click OK
>it would open up outlook express data file with .DBX extensions
>lets make sure outlook express closed
>lets rename the outbox.dbx to outbox.old
>lets reopen outlook express> but we will loose the outbox email
9/5/2022 9:01:56 AM • DBX -215 Home... • Answered on Sep 05, 2022
My outlook keeps a draft after i send email out
I have several Hotmail & Outlook accounts and I can use the drop-down menu to choose which one to use as the sender but sometimes if I don't use the actual email account (as the sender) that I am actually logged into at that moment, then it will not send the email and will put it in the Drafts folder instead. I went to the draft folder, chose the edit option and changed the sender email to the actual one that I was currently logged into, and that draft was FINALLY sent out.
12/26/2017 12:20:05 PM • DBX -215 Home... • Answered on Dec 26, 2017
Were is fuse for harman 215s equalizer
it may not have one, as most these units have thermal fuses in the transformers.. and they go bad, also it may use a wheat fuse...they look like resistors...if you are not familiar with these take it to a shop.
9/20/2014 3:09:15 AM • DBX -215 Home... • Answered on Sep 20, 2014
Voltage regulating ic number
which one, ???
9/20/2014 3:07:42 AM • DBX -215 Home... • Answered on Sep 20, 2014
I am getting voltage coming out the input think is the voltage ic gone bad
time for shop...
9/20/2014 3:07:22 AM • DBX -215 Home... • Answered on Sep 20, 2014
3answers
MY OUTLOOK EXPRESS IS FROZEN
>lets remove Security software and then check
>lets create new identity
http://support.microsoft.com/kb/209169
and then import the data back to new identity
8/29/2014 9:35:31 AM • DBX -215 Home... • Answered on Aug 29, 2014
How do i delete e- mails in drafts
Open Emails in drafts. Click on small square at begining, so that it becomes coloured. delete.
2/5/2012 4:36:15 PM • DBX -215 Home... • Answered on Feb 05, 2012
Hi, my DBX 215
Unfortunately, this is not a problem that is likely to be solved here without seeing the actual unit. Since one side works as expected, the first suspect of a power supply problem is not the case here. It is possible that you have an open ground or a defective bufer IC. Again, without testing the actual unit, it is impossible to state with any confidence what the exact problem is. I would estimate that a parts cost in the $20-$30 range is likely. This would cover buffer ICs as well as capacitors in the circuit.
Hope this helps a bit,
Dan
8/19/2011 12:31:05 AM • DBX -215 Home... • Answered on Aug 19, 2011
Is it posible to get
User manual for the DBX 131 215 and 231 graphic EQs can be downloaded from here:
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/dbx2SeriesManualA2.pdf
Rhett - I've mailed it to you.
3/23/2011 11:16:23 PM • DBX -215 Home... • Answered on Mar 23, 2011
Pls send me a connection diagram of how to connect
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/dbx2SeriesManualA2.pdf It's all in there. Here is a little extra guidance. if you are getting your left and right channels out through RCA you will need a RCA to 1/4 in adapter Radio Shack carries them relatively cheap. If it's already 1/4 or XLR skip this Left goes into Left in, Right goes into Right in. Then work backwards Right comes out of Right out, Left comes out of Left out. channel 1(left in) and Channel 2(right in) of your powered mixer. you should be set.
Good Luck, Cody J.
12/17/2010 8:34:08 AM • DBX -215 Home... • Answered on Dec 17, 2010
I cannot delete the emails in my draft folder before they send
Disable your internet connection. Start Outlook, Select all of the messages in your Draft box and drag them to the Delete folder.
Just curious, how did your get so many draft message in the draft box?
8/24/2010 3:48:01 AM • DBX -215 Home... • Answered on Aug 24, 2010
My daughter sent an email that had way too many
Depending on file size of the email, it might take a while after you hit delete, to actually delete. If using an online server for your email, this will happen. But how did it get to your sent box? Hope this helps.
4/2/2010 8:50:39 PM • DBX -215 Home... • Answered on Apr 02, 2010
Outlook express 6 sent messages stuck in outbox
possibly don't have enough free space on your drive
1/11/2010 5:51:03 PM • DBX -215 Home... • Answered on Jan 11, 2010
Outlook continues to send the same email and gives me an error
What is the error message?
Pictures too big?
Too many email addresses?
Size of email with pictures too large?
If it looks like SPAM to your ISP (Internet service Provider) then your email is being 'blocked'.
More info, please...
9/30/2009 6:52:54 PM • DBX -215 Home... • Answered on Sep 30, 2009
2answers
Emails stuck in Outbox
Tools > Options > Mail Setup > Send/Receive > Clear check mark on "Schedule Automatic Send/Receive every .. minutes" > OK
Close your Outlook > Open Outlook again > Go to Outbox > Select The message > Send To/Move To Draft
Go to Draft Folder and delete it from there
8/7/2009 5:46:34 PM • DBX -215 Home... • Answered on Aug 07, 2009
DBX -215 Home Equalizer Logo
Popular Tags
34 questions posted
Top DBX Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • DBX Audio Players & Recorders
Most Popular Question
cannot delete emails in draft folder
  • Audio Players & Recorders
