20 Most Recent
DBX DriveRack 480 Processing Unit Home Equalizer Questions & Answers
DBX DriveRack PA power failure
repair the transformers,,,using a digital voltmeter when both transfrormer are good the measure like 56 ohms, if one is good and the other is bad is gonna measure like 120 ohms , if both are damage it will measure nothing, all this with the switch in its on stage.
If you dont find anyone that can repair the transformers buy them.
Which Bass Sub?
go with the db15 active/powered sub. And cross it over at 90Hz.
I have a dbx driverack
Test the XLR cables that go in and out of the dbx. It's kind of a long shot but I think it's the best place to start.
Reset
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/PADriveRackManual%2018-1790V-B.pdf.
LOOK TO PAGE 36 IN THE ABOVE MANUAL.
Channel 1 plays but not 2
repeat your setting and check you control button and sliders--------try to exchange the cables if the good channel become dead change the cable.
if you did all above and still not working ask for help from service center.
No access to driverack 480 with belkin adapter
The Driverack Series all use a Null Modem cable for the connection to the Serial Port. A standard serial cable or female to female lead will not work, as the wiring has to be of the Null Modem type. A suitable lead should be available from your local PC supplier, failing that DBX can supply you with one also.
Hope that helps.
Jay
System speaker
Hello Sir,
Check this site for audio drivers. http://www.realtek.com.tw/downloads/
It will be useful. Check out..
Don't forget to comment
good luck
