20 Most Recent
Honeywell Pet Cleanair Air Purifier Hht082tgt Questions & Answers
What is this burning smell from my Honeywell air purifier
am sorry to disappoint you, once this condition is reached, it means the motor windings have overheated and your motor needs to be replaced, This is the only best thing to do to rectify this situation. This indicates that the insulation covering the wire used to make the winding of the motor has been cooked by the overheating and it is shorting out ,THIS WILL CAUSE THE MOTOR CATCH FIRE.
Please unplug the unit and have the motor replaced or buy a new unit for your safety.
How to reset indicator light on air filter
Hello, this is Ava with Think Crucial.
When resetting your Intelli-Check Filter Indicator. the air purifier should be powered on. Press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off.
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Changed filter and pre filter both lights continue to blink, not resetting
Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance.
Ava B.
