20 Most Recent Microsoft Xbox 360 Pro System Console Questions & Answers
2answers
My videos i downloaded from you tube to my pc wont play on xbox36
HI, these are supported for your x box 360
  • File Extensions: .mp4, .m4v, mp4v, .mov
  • Containers: MPEG-4, QuickTime
10/26/2018 10:00:09 AM • Microsoft Xbox... • Answered on Oct 26, 2018
0answers
The internet is connected to the xbox but the xbox live will not connect
Restart your modem or router, give it 30 minutes, and try again. If you still are not on live just check the tips they give you
2/10/2014 10:44:39 PM • Microsoft Xbox... • Answered on Feb 10, 2014
4answers
My powerbrick lightis orange but my xbox360 wont
If the light on the power brick stays orange after turning the console on it means the brick is not properly functioning. You can attempt to clean the power brick with a can of air. Also make sure it has ventilation and is not sitting on carpet. This can cause the power brick itself to overheat and cause issues with it and the console itself. Also make sure your 360 is not plugger into a surge suppressor as this can cause issue due to double protection.
If possible, test the power brick on a different console, and test the console on a different power brick. This will narrow down your problem area.
12/28/2013 10:43:15 AM • Microsoft Xbox... • Answered on Dec 28, 2013
Three red lights - General hardware failure.
Hi there daventonya
What to do when your xbox Has problems with flashing lights RROD/red rings of death.
You will need some simple repairs done on your XBOX as the GPU chip (Graphics) or the CPU chip (brain) or even both have lost connection to the motherboard Due to overheating.
Option 1
You can send this off to Microsoft if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Xbox to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $150 in cost
Option 3
What I recommend is a Xbox Repair Guide that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
xbox restore
Feel Free to leave me a comment if you need further assistance.
3/24/2011 10:33:44 PM • Microsoft Xbox... • Answered on Mar 24, 2011
Got wet
not good let dry for 3 days pray it doesent rust and try plugging in call 1-800-4my-xbo for more help
2/1/2011 4:26:57 AM • Microsoft Xbox... • Answered on Feb 01, 2011
3answers
E73 PERMANENT FIX
poop on it,that should fix it
1/20/2011 11:29:36 PM • Microsoft Xbox... • Answered on Jan 20, 2011
Having problems with x box
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
1/5/2011 3:41:52 AM • Microsoft Xbox... • Answered on Jan 05, 2011
Power supply light stays orange and wont turn on
I hope this helps The power supply light is orange for one of the following reasons:
  • The console is turned off.
  • The power supply is not plugged into the console or the connection is not tight.
  • The power supply is not functioning properly.
Note An orange light usually indicates that the power supply is connected to electricity and ready to power the console. When you turn on the console, the power supply light should change from orange to green. If your console does not turn on, please see the following Knowledge Base articles: 907588 (http://support.microsoft.com/kb/907588/ ) Your original xbox 360 console will not turn on
2122656 (http://support.microsoft.com/kb/2122656/ ) Your xbox 360 S console will not turn onIf the console will not power on and you have tried the troubleshooting steps in the above article, your power supply will need to be replaced.
Contact xbox Support to obtain a replacement power supply. For information about how to contact xbox Support, visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact)
1/4/2011 3:38:44 AM • Microsoft Xbox... • Answered on Jan 04, 2011
2answers
Xbox360
It seems that the sensor switch is not working inside the DVD tray, causing it to not lock and keep it inside.
Regards
James
www.fixmyconsole.co.uk
12/26/2010 1:59:39 AM • Microsoft Xbox... • Answered on Dec 26, 2010
2answers
MY xbox360 keeps telling me to reconnect
new batteries or bad wifi
12/19/2010 1:10:39 AM • Microsoft Xbox... • Answered on Dec 19, 2010
I was playing my cousins
try these steps
12/3/2010 8:46:18 PM • Microsoft Xbox... • Answered on Dec 03, 2010
Ring of death on third player
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via email at [email protected] and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new.
11/12/2010 12:56:16 PM • Microsoft Xbox... • Answered on Nov 12, 2010
2answers
It wont let me download the update that it keeps
Download the update from http://support.xbox.com/en-us/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx#copy on your PC unzip it to a usb memory stick and install it to the x-box from there.
Full instructions are on the link
11/1/2010 7:10:07 PM • Microsoft Xbox... • Answered on Nov 01, 2010
The bottom left of the ring on my XboX 360 keeps
Try holding the button down for 3 minitus and it will go green
10/31/2010 3:34:48 PM • Microsoft Xbox... • Answered on Oct 31, 2010
2answers
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
10/23/2010 12:28:08 AM • Microsoft Xbox... • Answered on Oct 23, 2010
Why can't I connect to xbox live by myself but i
dont waste money by going to repair shop........... with out knowing much you can repair your xbox with the help of this guide .........
it covers this problem so can download this soon to resolve this problem
click here to download..
10/15/2010 4:12:00 AM • Microsoft Xbox... • Answered on Oct 15, 2010
Microsoft Xbox 360 Pro System Console Logo
162 questions posted
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
Xbox Microsoft
  • Xbox Microsoft
Most Popular Question
three red lights general hardware
  • Video Game Consoles & Games
