20 Most Recent Jarden Health o Meter BFM884DQ1-60 Body Fat Monitoring Scale Questions & Answers
2answers
How to fix error E6 on a trojan evelotion platinum seriestreadmill
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
4/18/2024 10:08:37 PM • Exercise &... • Answered Yesterday
I need assembly instructions for wynne home gym.
Please check this link:https://www.google.com/search?sxsrf=ALeKk02D68ibDlpmqPFTdJFsPUAG8G7Hqg%3A1609823462652&source=hp&ei=5vTzX9vmJfG4mAXst4l4&q=assembly+instructions+for+wynne+home+gym&oq=assembly+instructions+for+wynne+home+gym&gs_lcp=ChFtb2JpbGUtZ3dzLXdpei1ocBADMgQIIxAnOgcIIxDqAhAnUIwSWIwSYPUXaAFwAHgAgAHwAYgB8AGSAQMyLTGYAQCgAQGwAQ8&sclient=mobile-gws-wiz-hp
4/5/2024 4:00:16 PM • Exercise &... • Answered on Apr 05, 2024
2answers
Where can I find a great treadmill deal on Black Friday 2023
The website TreadmillReviews.net has a black Friday page that you can see to find the best Black Friday deals https://www.treadmillreviews.net/sales/black-friday/. They have all the vendors and are featuring some of the best deals.
3/26/2024 8:02:23 AM • Exercise &... • Answered on Mar 26, 2024
What is the maintenance required for folding exercise bikes?
Cleaning: Regularly wipe down the frame, seat, pedals, and any other accessible surfaces with a damp cloth to remove sweat, dust, and debris. Avoid using harsh chemicals that may damage the bike's finish.
Lubrication: Apply lubricant to the moving parts such as the hinges, pedals, and resistance mechanism according to the manufacturer's recommendations. This helps prevent rust and ensures smooth operation.
Tightening: Periodically check and tighten all bolts, screws, and nuts to prevent loosening during use. Pay particular attention to the folding mechanism to ensure it remains secure.
Inspecting: Examine the bike for any signs of wear or damage, such as frayed cables, worn pedals, or loose components. Address any issues promptly to prevent further damage and ensure safety.
Storage: When not in use, fold the bike properly and store it in a clean, dry area away from moisture and direct sunlight. This helps prolong its lifespan and prevents corrosion.
Battery maintenance: If your folding exercise bike includes electronic components such as a display console, ensure that the batteries are replaced as needed to maintain proper functionality.
Regular servicing: Consider scheduling periodic maintenance checks with a professional technician to ensure all components are in good working condition and to address any potential issues before they escalate.
2/28/2024 9:12:11 AM • Exercise &... • Answered on Feb 28, 2024
Vitamaster 62C Exercise Bike. Maintenance - how to oil or grease where needed?
Question edited for clarity. Question moved from Food Mixers category. Same as a bicycle, so any parts that moves and has a pivot or a bearing. Help in the link https://www.google.com/search?q=Vitamaster+62C+oiling+or+greasing ..
2/22/2024 6:01:05 PM • Exercise &... • Answered on Feb 22, 2024
BodyTrain MT-196i Motorised Folding Bluetooth Treadmill. Brand new. Screen is working and programme can be set but motor will not start.
There is usually a breaker reset button near the motor. It is under maker warranty, so just contact them direct. https://www.google.com/search?q=BodyTrain+MT-196i+Motorised+Folding+Bluetooth+Treadmill ..
2/20/2024 6:27:09 PM • Exercise &... • Answered on Feb 20, 2024
Promaster pro plus 2 error code 31
Error 31 on your Promaster Pro Plus 2 treadmill could indicate a variety of issues, such as a problem with the motor or the motor controller. Here are a few troubleshooting steps you can try:
  1. Power cycle the treadmill: Turn off the treadmill and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. Sometimes, simply resetting the treadmill can resolve error codes like Error 31.
  2. Check the motor connections: Make sure all the wires and connections to the treadmill motor are secure and properly connected. Loose connections could cause error codes to appear.
  3. Inspect the motor controller: The motor controller regulates the speed and operation of the treadmill motor. Check for any visible signs of damage or overheating on the motor controller. If you notice any issues, you may need to replace the motor controller.
  4. Contact customer support: If you're unable to resolve the issue on your own, it's best to contact the manufacturer's customer support for assistance. They can provide specific troubleshooting steps for your treadmill model and may be able to offer a solution or arrange for repairs if necessary.
By following these steps, you can hopefully resolve Error 31 on your Promaster Pro Plus 2 treadmill and get it working again.
2/20/2024 3:17:53 PM • Exercise &... • Answered on Feb 20, 2024
Treadclimber TC 200 treadles rubbing in the middle
Check Alignment: First, ensure that the treadles are properly aligned. Misalignment can cause rubbing. Make sure the treadles are parallel to each other and evenly spaced. Tighten any loose bolts or nuts that secure the treadles to the frame. Inspect the Walking Belt: Examine the walking belt for any signs of wear, fraying, or damage. A damaged belt can cause uneven movement and rubbing. If the belt is worn out, consider replacing it. Lubricate the Bolts and Joints: Apply lubricant (such as silicone spray) to the bolts and joints where the treadles connect to the frame. This can reduce friction and prevent rubbing. Be cautious not to over-lubricate, as excess lubricant can attract dust and debris. Check for Obstructions: Look for any foreign objects (dirt, debris, or small items) that might be caught between the treadles or near the alignment bolts. Remove any obstructions to ensure smooth movement. Inspect the Alignment Bolts: Make sure the alignment bolts are properly adjusted. They should be tightened enough to prevent excessive movement but not too tight to cause rubbing. Adjust the bolts if necessary.' Test the TreadClimber: After performing the above steps, test the TreadClimber to see if the rubbing issue persists. If the problem continues, consider contacting the manufacturer or a professional technician for further assistance.
2/15/2024 10:31:07 PM • Exercise &... • Answered on Feb 15, 2024
Dripex resistance bike replacement resistance screw help.
Take the resistance screw to a local engineering shop and they will make you one. https://www.google.com/search?q=engineering+shop+near+me https://www.google.com/search?q=Dripex+9320+resistance+bike+parts ..
2/14/2024 11:22:26 PM • Exercise &... • Answered on Feb 14, 2024
Sole e95 level suddenly backwards. 20 is easy 1 is hard.
Watch this video if your resistance is backwards or stuck. This is a common problem and is caused by the linkage cable slipping off and ending up on the top of the flywheel instead of being on the bottom. Sole Elliptical E95 Stuck on High Resistance Fix (youtube.com)
2/14/2024 12:52:42 AM • Exercise &... • Answered on Feb 14, 2024
My treadmill not running after 7 seconds display shows
" after 7 seconds display shows.... "?? What does it show? All questions need full 'make model(what it is)' as first 3 words please. After 7 seconds it is likely to be overheating, stress on the belt, or the speed sensor has failed self test. Treadmills may stop due to several reasons: shut-down features to prevent overheating, excessive friction on the running belt, worn-out walking belts, and error codes indicating software or hardware issues.
Treadmill Stops While Running? Find Solutions Here!
More here https://www.google.com/search?q=treadmill+stops+running+after+7+seconds ..
2/13/2024 6:53:16 PM • Exercise &... • Answered on Feb 13, 2024
Jarden Health o Meter BFM884DQ1-60 Body Fat Monitoring Scale Logo
1 questions posted
Top Jarden Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Jarden Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Jarden Exercise & Fitness
Most Popular Question
batteries
  • Exercise & Fitness
