20 Most Recent Timex T42351 watch Questions & Answers
How to set alarm in
Hi rplokin,
I finally found the user's guide for your timex watch. I am attaching a picture of it, download the picture and view in full size to see how to set an alarm on your watch.
i hope i solved your problem, please vote and rate me.
Regards,
Salman
3/30/2021 1:32:12 PM • Timex T42351... • Answered on Mar 30, 2021
0answers
Which battery
Be the first to answer 12/13/2013 10:56:48 AM • Timex T42351... • Posted on Dec 13, 2013Be the first to answer
My watch stops every couple of houres. i press my
if there is anything else dont heatitate to contact me
3/5/2010 1:33:13 AM • Timex T42351... • Answered on Mar 05, 2010
Timex Triathlon Alarm Chronograph User Guide
i suggest you reset your watch
3/5/2010 1:32:14 AM • Timex T42351... • Answered on Mar 05, 2010
How can I use this and reset it ???
there should be a reset button on the watch have a good look closer but u will have to have something to reset it with you cant use your fingers
3/5/2010 1:31:13 AM • Timex T42351... • Answered on Mar 05, 2010
Alarm only works sometimes. What am I doing wrong.
get it checked out
3/5/2010 1:29:38 AM • Timex T42351... • Answered on Mar 05, 2010
Can't get the second hand to work
try reading the instuctions again if it still doesn't work then i suggest you take it to a shop or visit www.Repairwatch.co.uk then follow the instructions carefully.Thankyou
3/5/2010 1:28:10 AM • Timex T42351... • Answered on Mar 05, 2010
I need to know how to fully use my TIMEX t42351 watch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
2/10/2010 1:39:24 AM • Timex T42351... • Answered on Feb 10, 2010
How to change the date
I am not familiar with this watch, but most watches with hands allow you to pull the stem outward. If you pull it out all the way, the watch stops running. If you pull it out ALMOST all the way, turning the stem in one direction changes the day and turning it in the other direction changes the date. If you have only the date on your watch, then the almost all the way out will probably control that. Don't know if that will work, but it can't hurt to try it.
10/6/2009 9:45:42 PM • Timex T42351... • Answered on Oct 06, 2009
I have a Timex T42351
This watch has a cool feature that allows you to change only the hour if you are changing time zones. But if you want to change the minutes as well, then pull the crown out farther. You'll find that it has four positions: Normal, pulled out one notch, pulled out two notches, and pressed in to turn on the light.
Cool.
As long as we're at it, notice the crown in the four o'clock position also has three positions. In: set alarm. One notch out activates an alarm including the hour and minutes. Two notches out only activates the minute setting, so you don't have to move the hour hand all the way around.
Also cool.
5/22/2009 6:13:35 AM • Timex T42351... • Answered on May 22, 2009
Is there a manual for Timex women's T5K187?
https://www.google.com/search?q=Timex+women%27s+T5K187+manual It looks like you will have to contact Timex direct as the manufacturer doesn't list a manual for it although they do have other Ironman models. ..
3/9/2024 6:18:04 PM • Timex Watches • Answered on Mar 09, 2024
I left my timex solar watch in my watch case too long - and it stopped working. How do I repower the watch. (I have had it out in sunlight for a couple of days).
I am thinking you need a new battery. It appears to be a battery operated watch that runs on solar power IF there is light. How long will a Timex Solar watch last? The solar movement functionality creates an environmentally-friendly and maintenance free timepiece that can be charged through indoor fluorescent light or outdoor sunlight. Once fully charged, the battery life can reach two months. If worn daily, there is very little chance the watch will stop.
Solar Powered Watches ' Timex Blog
11/30/2023 7:43:05 AM • Timex Watches • Answered on Nov 30, 2023
Timex Expedition with Hydra Timer started randomly changing time and functions. Battery was replaced 1 year ago.
Either a loose connection inside or it just needs a new battery. They can be power hungry depending on how you use it and what battery technology type was used in the last one.
How Long Do Timex Watches Last? (Watch & Battery Life)
watchesoftoday.com https://watchesoftoday.com > Blog A Timex watch battery will last between two and five years, depending on how often you use the Indiglo feature, while the watch itself can easily last five to ...
8/26/2023 1:47:55 AM • Timex Watches • Answered on Aug 26, 2023
Timex T42351 watch Logo
19 questions posted
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
set alarm in
  • Watches
