20 Most Recent
Kenneth Cole KC2315 watch Questions & Answers
How to change the time
There is a set of instructions for KC watches but not by model name, only by dscription of appearance.
Go to
http://www.genevawatchgroup.com/ and scroll down the page and you will see a list of instructions. Pick out the english one (if that is your first language) and then scroll down the download until you reach the watch that looks like yours and study the instructions.
How to set time
To set a digital watch you must have two buttons.
There must be a "mode" button which steps through the setting screens and a "set" button which adjusts the current setting screen.
Keep looking to find the second button.
As a last resort you should speak to Keneth Cole (set their web site for contact details) and ask them to help you.
I need to set my
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields. J.
How do i set time on unlisted watch
dear sir
there r three buttons in which there r combination of buttons. your stopwatch button may not set the time . the middle button may set the time for u
No instruction book
The Kenneth Cole web site does not offer any downloads of instructions for watches, so I suggest that you go to their web site "kennethcole.com".
Select "find a store" (at the bottom of the page) and contact them to see if they can help you.
How to change the battery
the metal cover will be sliding and if you will slide it left or right battery should come out.
Thanks
How to adjust time, day or alarn on Kenneth Cole
There are 2 buttons on the right side, depress the lower round button
twice with a pointed object (like a pen). Only one number should
appear (month) advance if desired with the top square button. Depress
the round button again (once) to advance to next number and advance,
continue this until you complete the settings.....
How to setup the watch
There are 2 buttons on the right side, depress the lower round button twice with a pointed object (like a pen). Only one number should appear (month) advance if desired with the top square button. Depress the round button again (once) to advance to next number and advance, continue this until you complete the settings.....
Cannot set two button digital
There are 2 buttons on the right side, depress the round button with a pointed object (like a pen nib) twice. The date alone should display then you advance the number buy the upper square button. To get to the next option from date to month to hour etc...., depress the round button again (once) and continue 'til your done.
