20 Most Recent
Diesel Watch DZ7071 Questions & Answers
I cannot set the digital time on diesel watch DZ7101
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT DON'T FORGET TO RATE
Set time
I have just posted this problem on here myself but have also just found the solution after searching the internet so here it is..........
Hold down the top left hand button which is for the light and then a
menu should come up saying 'LIGHT' & the option for on or off, ignore this & press the bottom left button, the next option is for the 'CHIME' & on or off, press bottom left button again & the option for 'TIME' comes up. Use the buttons on the right to alter the time until it is correct and then press the bottom left button again for
the date and select the correct month and day and year and then you
are all set up! Hurray, a watch that tells the time, im chuffed!
