20 Most Recent
Nordic Track NordicTrack AudioStrider 990 Pro Elliptical Questions & Answers
Why is my elliptical not gliding smoothly?
I do not know anything about your machine. But from a general mechanical standpoint. It sounds as if the belt is not routed properly, or is the wrong size. You can also inspect where the belt rides for debris from the old belt. Something could be stuck somewhere. Hope this helps. Good Luck!
NordicTrack treadmill EXP 1000
Please note that these instructions don't apply to all models of treadmills. Many recent models, including all models with touchscreen consoles, do not have the capability for the user to calibrate the speed.
Speed calibration is a process that is used to correct imbalances in the machine's operating speed.
Please note that this procedure involves pushing the machine to its maximum speed very quickly. Do NOT stand on the treadmill while performing this procedure.
First, you need to enter calibration mode on the console. To do this, press and hold the STOP and SPEED INCREASE buttons (this will be either an up arrow or a + (plus) symbol). While holding these buttons, insert the safety key onto the console. This will cause the machine to go into calibration mode. After this has occurred, you may let go of the buttons and the safety key.
Next, press the stop button once. This will enter advance the screen to the next feature of calibration mode. As said previously, do not stand on the treadmill while performing this procedure. Press and hold the speed increase button. Watch the console. You will see a number on the display that will increase as you hold the speed increase button. Continue to hold the speed increase button until the number changes to "85." This will take the treadmill to its maximum speed, which will also be displayed on the console. Please note that the example below only demonstrates the console displaying "85", not the treadmill's operating speed.
Elite 7700 treadmill. Why is there no power to console?
If the electrical outlets work and are fine unplug the treadmill and then check the power cord for any damage. Replace the power cord if it's damaged. If the power cord is fine and looks fine then check the circuit breaker switch on the treadmill and reset the circuit breaker switch if it's tripped.
