20 Most Recent
Tag Heuer Link Series Dual Time Gmt WJF2116.BA0570 Watch for Men Questions & Answers
How do I set the alarm on model wau111a tag watch
Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
Instruction manual
If the second is ticking as normally it is not the battery. If the battery is low the second hand will advance only at 5 second intervals meaning for four seconds the second does not move and on the 5th second it will advance by five seconds. This is a feature unique to Tag Heuer.
What kind of watch winder do I need for this watch
You have selected a wonderful watch... Heuer and TAG/Heuer should be gently wound by the motion of the human wrist and the falling of a centrally pivoting weight (there is no ideal direction).
AUTO-WIND function is NOT at all unique to your watch...
After a couple of CHEAPER "winders" failed me... and after I figured about 4 watches was more than enough to keep wound... I found the greatest BASIC watch winder... to run year over year (efficiently and quietly)
MTE watch winder (their very basic WTS-4).
Good luck: I WILL try to include the URL (see page 6)
http://mte-watchwinder.com/fileadmin/PDF-Uhrenbeweger/MTE_Watch_Winder_Brochure_Engl.__09-2015.pdf
7/30/2020 12:51:36 AM •
Tag Heuer...
Answered
on Jul 30, 2020
