20 Most Recent ESQ 07301132 Aerodyne watch Questions & Answers
Setting time day date in ESQ Aerodyne
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
9/13/2017 7:19:04 AM • ESQ 07301132 ... • Answered on Sep 13, 2017
0answers
0answers
2answers
I just bought this watch
1/23/2013 7:16:27 PM • ESQ 07301132 ... • Answered on Jan 23, 2013
2answers
How do you change the country
Thank you for contacting FixYa.
I would contact ESQ at the following link:
http://www.esqswiss.com/
Best regards. Jewel
1/4/2012 10:52:08 PM • ESQ 07301132 ... • Answered on Jan 04, 2012
2answers
How do I set the
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
1/4/2012 10:49:57 PM • ESQ 07301132 ... • Answered on Jan 04, 2012
I have an ESQ Aerodyne and the time set by the
this watch needs to be taken in as this is not proper time telling. has the johnson rod been used yet. if not, do so. if so have it taken in and checked with a caver device.
1/1/2010 5:00:22 PM • ESQ 07301132 ... • Answered on Jan 01, 2010
Watch doesn't work
It would be difficult to state with certainty, because it wouldn't likely be possible to determine how long the watch was in storage before you received it. Most watches will need batteries between 2-5 years after their manufacture.
Higher-priced watches could easily be that long on the shelf before sale, but I would contact the seller with your complaint. The seller should at least be conscientious enough to ensure the watch is running prior to shipment.
11/20/2009 12:38:09 PM • ESQ 07301132 ... • Answered on Nov 20, 2009
How do you set time
i need to remove links from my sons fossil watch how do you do this?
4/4/2009 6:45:47 AM • ESQ 07301132 ... • Answered on Apr 04, 2009
What battery do I need for a ESQ Swiss men watch model # E5081
Here where we live we have a store that replaces watch batteries. I took mine in and he took the back off and took the old battery out and went to his battery stock and replaced it for me. He did all the work and only charged me three dollars. He has batteries for all makes.
3/5/2019 9:00:32 PM • ESQ Watches • Answered on Mar 05, 2019
0answers
ESQ 07301132  Aerodyne watch Logo
24 questions posted
Top ESQ Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an ESQ Watch Expert? Answer questions, earn points and help others
View Most Popular
ESQ Watches
  • ESQ Watches
Most Popular Question
setting time day date in esq aerodyne
  • Watches
