20 Most Recent Cartier New Pasha Seatimer Steel W31077U2 Watch for Men Questions & Answers
0answers
How can i check a serial number for a cartier
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
3/23/2010 12:35:08 PM • Cartier New... • Answered on Mar 23, 2010
0answers
Is the men's diamond wedding ring real serial #0905524
A genuine Cartier ring will be stamped on the back with Cartier's logo, the jewelry's metal type (Au 750 or 750 for 18k gold or Pt 950 or 950 for platinum), the ring size in mm, and a unique serial number. The stamp should be evenly spaced and, of course, free of any spelling mistakes. Best to you
12/7/2022 10:44:20 PM • Cartier Watches • Answered on Dec 07, 2022
Cartier tank solo XL change set date
On that type of movement that are normally three clicks to the winder. One of then does Date when you turn it one way and Day when you go the other. Warranty is 24 months
Cartier limited warranty USA / Canada
https://www.en.cartier.com > care-adjust-repair > watches Your Cartier watch is warranted against any manufacturing defect for a period of twenty-four (24) months from the date of purchase (the "Warranty Period") ...
1/15/2022 1:17:06 AM • Cartier Watches • Answered on Jan 15, 2022
2answers
HI I wont to know battery size to my watch must de cartier serial # 901014991
Not a good idea. What starts as a 'simple battery change' could result in $500 in repairs. It is a Cartier! If it is a fake Cartier then by all means destroy it. Just realize that you don't really know what you are doing and you are about to perform brain surgery on a very expensive watch.
2/12/2021 10:47:36 AM • Cartier Watches • Answered on Feb 12, 2021
IS MY CARTIER WATCH AUTHENTIC SERIAL NUMBER 84460CF 4117
It is fake, i have the same one
12/6/2020 3:18:55 PM • Cartier Watches • Answered on Dec 06, 2020
How do I change the flint on my Cartier lighter?
I am not familiar with this particular lighter, however, changing flints isn't usually difficult. Could you post a photo of the underside of the lighter? Try turning the lighter upside down. There should be two sections moulded in the bottom of the lighter. One is the refill port you use to fill it with gas, the other will be the adjuster or mount for the flint. The flint holder is usually a Spring loaded tube with the flint mounted at the top end. Carefully unwind the screw or twist cap being careful the spring doesn't suddenly release. This should slide out letting the remains of the old flint fall out. You may need to GENTLY tap the lighter to knock out any dust left by the old flint. Insert the new flint, insert the retaining pin and screw it in until it is finger tight. Screw too tight and you could crush the new flint or damage the screw thread on the retaining pin.
10/13/2020 2:41:45 PM • Cartier Watches • Answered on Oct 13, 2020
CARTIER ARGENT G20m 89007L fake or real
Take to a jewellers who will have to take the back off...
11/2/2019 10:23:32 PM • Cartier Watches • Answered on Nov 02, 2019
Identifying a cartier lighter by serial number
try putting all its details in to google search..or put all details on here and someone might be able to help you out.
3/22/2019 8:03:38 PM • Cartier Watches • Answered on Mar 22, 2019
How do i know a
The best way is to have a watchmaker remove the back of the watch. The counterfeits usually have a cheap movement inside and that can help determine if its real or not.
2/28/2019 7:22:29 PM • Cartier Watches • Answered on Feb 28, 2019
I need a serial number verified for my Cartier watch to know if it's authentic. I took it to a jeweler and it was swapped out for a fake.
what model is it do u have pics and why do u think it was swapped for a fake
2/25/2019 8:58:06 AM • Cartier Watches • Answered on Feb 25, 2019
I need to check a serial number on a cartier watch
Sorry we can't provide that type of info here.
2/12/2019 8:25:32 PM • Cartier Watches • Answered on Feb 12, 2019
How do I check the authenticity of Cartier eyeglasses(other than taking them to a jeweler)?
Hello, Brandt - If the glasses frames were not purchased from an authorized Cartier eye glass frames retailer, the tips here describe how to spot fake eye glasses frames: http://www.detectafake.com/viewProduct/?269653 Read the information here, as well: https://blog.designereyes.com/real-cartier-glasses-vs-fake-cartier-glasses/ Best wishes.
1/16/2019 7:29:39 PM • Cartier Watches • Answered on Jan 16, 2019
Cartier New Pasha Seatimer Steel W31077U2 Watch for Men Logo
Popular Tags
6 questions posted
Top Cartier Watches Experts
k24674
john h
ADMIN Andrew
ADMIN Andrew
Are you a Cartier Watch Expert? Answer questions, earn points and help others
View Most Popular
Pasha Cartier
  • Pasha Cartier
Most Popular Question
check serial number cartier
  • Watches
