20 Most Recent Stoves Premier 600GRa Gas Single Oven Questions & Answers
as it is when your oven runs normally it usually does an on and off type of running in which the ignitor lights the flame from the gas which stays on until the oven tempreture sensor tells the control board that the oven is hot enough at which time it shuts off the gas until the oven starts to go maybe 10-15 degrees below the tempreture at which time it would let the gas go through the line again and turn on the ignitor try checking your ignitor usually if you stick an amp meter on them should be drawing 3.3 amps plz remember to shut off the gas from the gas shut of valve in the rear of the machine before measureing for the amps hope this helps
Stoves Premier... | Answered on Jul 13, 2010
Check out this tip... just because you get a glow from the ignitor, that does not mean that it is not bad...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Stoves Premier... | Answered on Apr 26, 2010
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Stoves Premier... | Answered on Apr 04, 2010
air pressure switch broken oven thinks the fan is not working and turns it self off.
Stoves Premier... | Answered on Feb 24, 2010
I got technician locally to came and sort out. He says it can happen but often but there is a chance and I was the unlucky one.
Stoves Premier... | Answered on Jan 11, 2010
if voltage to clock bad clock if no voltage to clock bad board
Stoves Ovens | Answered Yesterday
Sometimes these controls are custom and need to obtain an exact fit OWM replacment (rather than a generic part.)
If your in the UK, try contacting
B Grade Domestics,
1, Armscroft Road, Barnwood,
Gloucester. GL2 0SQ,
UKSupport: 01452341595E
mail: nick.bgrade@gmail.com
Stoves Ovens | Answered on Jun 26, 2019
check voltage to display board if no bad transformer if voltage bad display or control board
Stoves Ovens | Answered on Apr 30, 2019
check that it is not in auto or timer mode
Stoves Ovens | Answered on Mar 20, 2019
Stoves Premier 600GRa Gas Single Oven Logo
12 questions posted
Top Stoves Ovens Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
View Most Popular
Stoves Ovens
  • Stoves Ovens
Most Popular Question
get pilot light stay lite in oven
  • Ovens
