20 Most Recent Stoves Premier 720GRa Gas Double Oven Questions & Answers
hi everyone, i hope this helps.
you may need to take the oven out and use a vacuum cleaner to **** out the dust from the back of the oven, i found that this is the cause for ovens not lighting and grill not working, its a simple thing to do, just pull the oven out and at the back you will see where all th dust has accumulated, just vacuum it out
and it should work. i have had so many problems that i am going to replace the whole piece of **** now that the fans have packed up !
stoves know that the ovens are rubbish and unreliable, but have done nothing to help (even the engineers know this)
Stoves Premier... | Answered on Apr 13, 2016
ignition probably serves both, if clicking when not lighting, fault or sticking button
Stoves Premier... | Answered on Jan 04, 2016
good day,
hope this link below will solve your problem.
ovens
Stoves Premier... | Answered on Aug 03, 2010
grill switch will not turn on grill
Stoves Premier... | Answered on Jul 27, 2010
you solved this problem / replace the display . it should correct problem .. ..mm
Stoves Premier... | Answered on Jul 15, 2010
If your oven uses silicone carbide ignitor and the ignitor is glowing the problem could be the ignitor is not drawing enough amps to open the gas valve. If the valve is open the ignitor will not glow. If the ignitor is bad it won't ohm out.
If your oven uses DSI (direct spark ignition) It may be that the gas distribution valve has a bad solenoid. The valve has 3 terminals: broil on top common in the middle and bake on bottom. You should get 216 ohms between broil and common and bake and common. If either one is open the valve needs to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Stoves Premier... | Answered on Jul 09, 2010
you have to be able to check the ignitor in the lower oven sounds like you have a weak ignitor when this happens it is taking to long for the oven to light and when it reaches to a tempreture it shuts off the ignitor in which case when it trys to reach to the tempreture that you have set it trys to ingnite again look to buy a new ignitor
Stoves Premier... | Answered on Apr 28, 2010
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Stoves Premier... | Answered on Jan 24, 2010
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Stoves Premier... | Answered on Apr 15, 2009
Stoves Premier 720GRa Gas Double Oven Logo
45 questions posted
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
View Most Popular
Stoves Ovens
  • Stoves Ovens
Most Popular Question
grill ignition click when bottom oven
  • Ovens
