20 Most Recent
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Defy repair manual
you will need to have a gas registered engineer who can do cookers for this to be done as they have to be registered with gas safe you cannot just " work" on gas appliances. Sorry
Overheating
The top cooling fan is not working which cools the electrics above the oven and the control panel at the front. It could be the fan is faulty , the pcb which controls it is faulty - inside back panel on right. There is also a resistor on the power to the fan which burns out. All easy do it yourself fixes if you are electrical competent.
Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
