20 Most Recent
Power Acoustik Poweracoustik Pcnc2.0f Capacitor Questions & Answers
How do i hook up my power acoustik capacitor the
HEY GUY..FIRST THING....GOOD JOB IN GETTING A BIG CAP :) ...SECOND I HAVE WIRED THESE FOR YEARS..ITS REALLY VERY EASY.......THE OBJECTIVE IS TO PUT THIS IN LINE WITH YOUR AMP....SO WITHIN ABOUT A FOOT AND A HALF OF YOUR AMP..YOU WANT TO 1.. CUT YOUR POSITIVE AND NEGATIVE WIRES RUNNING THE POWER TO YOUR AMP...2. YOU WILL THEN CUT THE INSULATION OFF AROUND THE POSITIVE AND NEGATIVE WIRES ON BOTH ENDS OF THE WIRES YOU HAVE JUST CUT(YOU WILL END UP HAVING THE 2 POS AND 2 NEG. WIRES WITH THE INSULATION PEELED OFF)... 3... YOU WILL THEN JUST HAVE THE 2 WIRES (WITH THE INSULATION GONE OFF OF THEM) OUT OF THE AMP..AND THE OTHER 2 STRIPPED OFF RUNNING TO THE CAR BATTERY (POS) AND THE (NEG) TO THE CAR FRAME OR NEG BATTERY POST... 4.. YOU WILL THEN JUST MATCH UP THE POSITIVE FROM THE AMP INTO THE POSITIVE ON THE CAP...AND THE POSITIVE GOING BACK TO THE BATTERY OF YOUR CAR TO THE POSITIVE ON THE CAPACITOR...DO THE SAME THING WITH ALL OF THE NEGATIVES.......
SUMMARY.... CUT THE NEG. AND POSITIVE WIRES.WITHIN 1.5 FT FROM THE AMP.... PEEL INSULATION ON WIRES BACK ABOUT .5" ON ALL 4 WIRES.... PUT ALL THE POSITIVES TOGETHER AND ALL THE NEGATIVES TOGETHER...AND YOU CANT GO WRONG....THANK YOU
Good Luck
Power Acoustik PD-624B 6.2-Inch Double-Din in-Dash LCD Touchscreen DVD Receiver with Bluetooth. The Radio cannot play any video, gives warning message.
Question edited for a lot more clarity, full make model (what it is)'.
Question moved from Televisions category.
The warning message may have been useful!
People don't realise that factory car audio is operated by and monitored by the Body Control Module (BCM) on a computer network. Your warning chimes and indicator clickers are generated by the BCM and played through the car audio system. The computer has no idea that this new device is!
Take it to an auto electrician or to an Alarm / Audio installer and see if their professional bi-directional grade scan tool computer can reprogram the BCM to ignore your device. Or just put the old one back.
I have a power Acoustik cpaa7dd double den car radio and I keep getting unknown disc errors
- Make sure the disc you are trying to play is compatible with the radio. The radio may not support certain formats or types of discs.
- Check the disc for any visible damage, such as scratches or fingerprints, that may be preventing it from playing properly.
- Check the CD player for any debris or foreign objects that may be preventing the disc from being read properly.
- If you are using an aftermarket CD changer, make sure it is properly connected to the radio and functioning correctly.
My power acoustik pd-620hb won't turn off
POWER/MUTE Button Press it to turn on the unit.Press and hold for 2 seconds to turn the unit off . Press the button briefly to Mute . Please note that the volume will be muted on all audio output connector.
I have a power acoustik pd 701 how do I play videos off my iPhone thru usb cable
- Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
- Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
- Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
- Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
- Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
I have a Power Acoustik PD-710,,I cant get my USB to work. It keeps saying USB error. I have checked my usb on my laptop and other car stereo and it works. It dont work with the power acoutik
Okay I am assuming that you are referring to a USB thumb drive aka memory stick which contains mp3, wma (YOUR STEREO ONLY PLAYS MP3 AND WMA VIA USB NOTHING ELSE MANUAL SAYS) audio tracks and a certain specific format (formatting is done on computer, windows and different types of formats are supported on different devices). NTFS, fat32, exfat. Typically I think they like fat32 before but I have had all of my drives formatted for NTFS on newer equipment and had no issue with it. Um since you checked the drive and its working it's probably not that. It could be the connector on your stereo there. But if its new it's probably a formatting/compaitbility issue with the stereo. Heres the manual
http://www.poweracoustik.com/pa2012/manuals/PD-710-T.pdf Also this stereo is a really cheap brand so they don't work as well and dont have that great of support. A Google search of that an similar stereos from them came up with several issues. There is very little USB power coming from that port so it's probably only enough power to connect a thumb drive. Some people have cables connecting to other devices and that is probably not going to work. I would get a different usb stick reformat it on the computer and copy some mp3's over.
