20 Most Recent Power Acoustik Pcnc3.0f 5 Farad Digital Power Stiffening Capacitor Questions & Answers
A device used to store an electric charge, consisting of one or more pairs of conductors separated by an insulator.
Power Acoustik... | Answered on Apr 17, 2016
How many uf is indicated on the capacitor.It will show a number ie 10uf. If the rating on the capacitor is more than 5uf or less than 3 uf then the capacitor is failing. 10% variance is acceptable. Most electrical wholesalers sell capacitors and cost is around $20.00 or so.
Power Acoustik... | Answered on Mar 26, 2013
it's like a battery. you run it in parallel (run power from battery + to capacitor + then from capacitor + to ampplifier +) battery, capacitor, and amp each has its own ground (black or -). you don't need a remote wire. it only stores electricity until the amplifier needs extra juice (so your headlights won't dim).
Power Acoustik... | Answered on Jul 24, 2011
i think it will read anywhere Between 12 and 14 Farad.. not Positive but hope this helps ;-)
Power Acoustik... | Answered on Mar 17, 2011
Del corriente de la bateria al positivo del capacitior. De la tiera de capacitor al positivo o corriente del amplificador. Bueana suerte.
Power Acoustik... | Answered on Feb 14, 2011
You hook it up in parallel with your amp. You'll see a and - on the clear plastic cover.
Hook a wire from your amp or positive to the capacitor
Hook another wire from your amp - or negative to the - on the capacitor.
That's it, you're done.
If the plastic cover is missing, or painted over, with the neon tubes at the top, and the connector/display end facing you, the right side is the left side is -.
Power Acoustik... | Answered on Aug 29, 2010
Cap is hooked up wrong, should shut off after a certain amount of time and reactivate with the ignition hot wire. If it's draining your battery continuously then you should look at the wiring.
Power Acoustik... | Answered on Dec 24, 2009
look closely you will see a plus ( +) sign , it means positive
to be connected to the positive of the battery there is + sign also.
the negative ( - ) sign can be connected anywhere your car chassis or
the negative of the car battery.
Power Acoustik... | Answered on Nov 02, 2009
Use to independent grounds always better that way. Better full field for power and less distortion. I like to use 4 guage or lower like 0 guage for high powered systems. Good luck, thanks for using FIX YA
Power Acoustik... | Answered on Jan 27, 2009
Search google for a schematic should be able to find one. I repair amps. Marks Car Audio & Amp repair
e-mail skinnman33 @gmail.com I can be reached at 727-266-6398 Let me know
Power Acoustik... | Answered on Apr 01, 2019
It depends on how many channels are on the Amp. If it's a 2 channel you can bridge it using the positive on one channel and use the negative on the other channel. The Amp will give the sub more power bridging the sub.
Power Acoustik... | Answered on Mar 10, 2019
Power Acoustik Pcnc3.0f 5 Farad Digital Power Stiffening Capacitor Logo
17 questions posted
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
am going connect car im
  • Car Audio & Video
