20 Most Recent
Stoves 1000DFDL Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
I have a newhome1000df. can it run on lpg?
If it's designed to run on natural gas then usally the answer is yes but it will need to be converted the orifices for LPG are a different size than for natural gas. Trying to run it without converting is dangerous!
Oven not heating up but fan comes on, in the larger oven . Model 1000dfdl
Main oven element probably needs replacing, usualy they only last about 4-5 years depending on usage, fairly cheap to replace, around 15 pounds for the part, fairly easy job for diy enthusiast, or no more than 30 mins work for a appliance repair person. On most ovens, first isolate the oven for safety at the double pole switch outlet. open oven , remove all shelves etc, look for a metal cover at the back which covers the fan and element, usualy two or three screws on the cover to remove, behind cover you see the element and fan, remove two screws on the element mounting plate and carefully pull out with the wires, carefully pull off the two connectors on the element, connect new element and fit in reverse procedure of above.
I want to install a richmond 1000df range cooker
You must , by law be a registered Gas Safe Engineer to connect this cooker to the gas point , they will also chain it for you. You can find a Gas Safe engineer at
www.GasSafeRegister.co.uk then , enter your postcode in the required box and you will be given a list of Gas Safe engineers in your area or ring freephone 0800 408 5500 to get this information .
Heatilator gas fireplace orphis
Hi follow the gas line from the outlet of the gas valve to the burner injector is there you will have to remove the burner and change pilot injector aswell
Newhome 1000dfdl main fan oven appears to stay at
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element whilst the temperature light remains on.
but if the temperture light is off then its likely to be a faulty thermostat
Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
