20 Most Recent HP DVD1040e DVD-RAM Burner Questions & Answers
3answers
I dont know how to
open up your burning program depending on which burning program you have you can select either dvd or cd to burn an iso or make a cd/dvd movie once you have made your choice a browser should open navigate to your video file/s select it you might have to select an iso ((will depend on which burning program you have)) add to you should a graph oh how many mbs have been used once it loads select burn if you dont have any burning software to burn dvd's there are plenty of free burning software programs on the internet
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).hope this helps you
3/25/2020 9:42:33 AM • HP DVD1040e... • Answered on Mar 25, 2020
I bought a new desktop computer and I can't seem to get Windows 10 to recognize the burner. I don't know what will be needed, in order, to get the burner working with Windows 10.
It's probably just a case of finding the right drivers for it. Search for your burner make and model number with the word "drivers" and see if any come up for Windows 10.
3/25/2016 11:31:48 PM • HP DVD1040e... • Answered on Mar 25, 2016
I currently have Windows 10 on an ASUS desktop PC and I can not get an HP dvd1040 writer/player that was on a Windows XP machine to be recognized by the Windows 10 machine. What are my options?
reinstall the writer /player driver in the win 10 os as it is too far removed from xp to be recognized
2/12/2016 5:15:43 AM • HP DVD1040e... • Answered on Feb 12, 2016
Can I transfer cassette tapes to this unit?
Not in the same format as on the tape. They would have to be converted to digital music files such as MP3 first. That would require audio capture software on the PC. Then, once you have the music converted, you can burn it to the CD/DVD.
12/18/2015 2:24:29 AM • HP DVD1040e... • Answered on Dec 18, 2015
I lost my hp dvd 1040 installation disc. I need
h30434.www3.hp.com/t5/Printer-All-in-One.../hp...dvd-1040.../13035
3/25/2011 5:29:43 PM • HP DVD1040e... • Answered on Mar 25, 2011
I need de copy to manual hp dvd 1040e please send
http://h10032.www1.hp.com/ctg/Manual/c00944297.pdf
that's the link for the manual!!
akuma_ryu21 rate it pls!!
1/21/2011 12:37:16 PM • HP DVD1040e... • Answered on Jan 21, 2011
My computer does not recognize hardware. FYI:
These are the steps to resolve the issue for the cd/dvd icon missing in the My computer.
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
12/6/2010 6:34:00 PM • HP DVD1040e... • Answered on Dec 06, 2010
Dvd burner will not recognize blank dvd's. have
u must change the burner software to any other.
9/22/2010 11:16:02 AM • HP DVD1040e... • Answered on Sep 22, 2010
2answers
My xp computer suddenly stopped recognizing my Hp
I've found HP to be very helpful getting updated drivers, but perhaps not on this one. Have you tried a search with the model number (hp dvd1040e driver)? I found it at opendrivers. I hope this helps you.
6/11/2010 12:22:14 PM • HP DVD1040e... • Answered on Jun 11, 2010
2answers
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
5/31/2010 8:52:51 PM • HP DVD1040e... • Answered on May 31, 2010
Problem with burning DVD
This should help you its free this link is an email address that will acces the HP experts for support I know it says pavillion in the email they will forward it to the right area just provide the modle number and the issue the rest will be taken care of throught the expert.
[email protected]
1/6/2010 4:07:17 AM • HP DVD1040e... • Answered on Jan 06, 2010
I have 2 dvd writer drives that are not being found by software
get on the computer manufacturers website and download the drivers for your dvd on there.
5/24/2009 3:41:05 AM • HP DVD1040e... • Answered on May 24, 2009
Without admin rights I am allowed to burn or lightscribe.
You should be able to unless he has specifically set rules against this. I am the IT guy for my company and they can burn DVDs and lightscribe.
Slap your IT guy around is the fix for this one.
4/29/2009 4:28:57 PM • HP DVD1040e... • Answered on Apr 29, 2009
HP DVD 1040 external lightscribe
  1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
  2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
  3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
    double-click on Lightscribe Service, and if it says disabled change it to automatic, then "start service" in the left pane if is already started and set to automatic stop and restart it you don't have to reboot to see results.
It worked for me on HP6710b with internal drive and with liteon external burner
1/19/2009 3:35:33 AM • HP DVD1040e... • Answered on Jan 19, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
HP DVD1040e DVD-RAM Burner Logo
19 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
bought new desktop computer seem get
  • Computers & Internet
