20 Most Recent JBL PSW-D110 Speaker Questions & Answers
6answers
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
3/4/2014 12:58:13 PM • JBL PSW-D110... • Answered on Mar 04, 2014
0answers
My JBL PSW-D110 started humming loud..
Hi calsunbelt
there are some caps that fail in the power supply. If you are up to doing some electronic repairs, I could talk you through it and tell you what parts to check.
regards
robotek
1/27/2013 10:43:11 PM • JBL PSW-D110... • Answered on Jan 27, 2013
2answers
My sub has no power, ther could even be other
Hiya, start by checking the power cable, then check the fuse in the unit on the pcb. If blown, replace and if it blows again then problem could be either Power supply or the amp outputs. If it doesnt blow, stays on but no sound, problem also likely to be output stage. You will need someone with experience to check outputs, etc and a meter though. Hope that helps a bit.
Best of luck
9/8/2011 8:36:55 PM • JBL PSW-D110... • Answered on Sep 08, 2011
How should it be wired
8/15/2011 3:52:50 PM • JBL PSW-D110... • Answered on Aug 15, 2011
I have a PSW-D112 that
What happens if you disconnect only the source end of the RCA's? Atmospheric noise can enter through the cables if their shields are grounded well.
Google: "speakers buzzing"
8/3/2011 9:19:32 PM • JBL PSW-D110... • Answered on Aug 03, 2011
Speaker will not turn on.
There is a fuse inside (250 volt 2.5amp slowblow)
Check and replace C6 with a 10ufd 100volt non polarized capacitor.
I have a service manual if you can not find one!
7/30/2011 5:08:51 AM • JBL PSW-D110... • Answered on Jul 30, 2011
How remove back panel
Remove all screws from back panel grab power cord and pull. The panel will pop off!
7/30/2011 5:06:26 AM • JBL PSW-D110... • Answered on Jul 30, 2011
What is the size of
The fuse is a 250volt 1.25 amp slow blo.
First thing I would do is check C6 to see if it is bulge or blown - regardless replace it with a 10ufd 100volt Non-polarity capacitor. If the fuse blows again unplug the blue wires from the transformer and plug in unit to an outlet. If fuse does not blow then problem is on PC board. I have a service manual for this item. Probable causes on PC board are Filter Caps, Bridge rectifier (DBA), Amplifier module, or fragments of C6 even causing shorts on board if it had blown.
I have bought C6 from MCM Electronics for under .50 cents but you have to put shrink tube on one lead and bend it back along the body and solder both leads in the board.
Good luck
7/30/2011 5:04:23 AM • JBL PSW-D110... • Answered on Jul 30, 2011
Hi can you tell me
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
7/4/2011 1:06:47 PM • JBL PSW-D110... • Answered on Jul 04, 2011
Good afternoom, i need to
It is the Class D power amplifier module that JBL uses a lot in the powered sub-woofer, they are very unreliable and hard or impossible to get.
I had modified them to use linear power amp IC instead.
http://s807.photobucket.com/albums/yy352/budm/JBL%20PB-12%20mod/
4/19/2011 6:05:00 PM • JBL PSW-D110... • Answered on Apr 19, 2011
0answers
JBL PSW-D110 Speaker Logo
62 questions posted
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Audio Players & Recorders
Most Popular Question
psw d112 sub woofer
  • Audio Players & Recorders
