20 Most Recent
Philips SWV6813-17 HDMI 3-Way Switcher Questions & Answers
HDMI picture is saturated in the wrong color
The problem is generally the cables, period. If there is a condition whereby the cable was bent, kinked, overheated, or the end damaged in any way, this problem can exist. Many times when a cable is attached to the device, it is cross-threaded or left loose. If the contact is not 100%, you can experience this condition. I suggest that you obtain NEW cables and connect them tightly and firmly in place. This should eliminate the problem, UNLESS the male connection on the device/s have been compromised.
1/14/2018 5:48:34 PM •
Philips...
Answered
on Jan 14, 2018
I want to add pictures to my philips digital frame
This works when using memory cards or USB flash drives. Turn on the frame. Insert card/flash drive. Screen should come up asking if you want to add photos to internal memory. You will have 15 seconds to respond. "No" will be highlighted. Press "left" (<) arrow button to highlight "yes". Press "OK" button. Frame will begin importing all photos on the card/flash drive.
