20 Most Recent Coby DP-5588 5.6-Inch (4:3) Clock & Digital Photo Frame with MP3 Player (Maple) Questions & Answers
3answers
Installing coby digital keychain software
Start from scratch, uninstall everything and pretend your installing for first time:
1. have keychian unconnected from usb
2. install software
3. DONT RUN SOFTWARE YET
4. connect keychain to usb
5. on keychain select: USB update
6. Run software
7. well-ah, intelligence > poorly organized device - enjoy everyone
12/22/2018 8:51:46 AM • Coby DP-5588... • Answered on Dec 22, 2018
0answers
I have a digital photo
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
12/5/2010 8:19:31 PM • Coby DP-5588... • Answered on Dec 05, 2010
I bought a coby digital photo frame (DP5588). I
Hello you were not misinformed about the audio capability but you may have been misled. The only audio formats which your frame supports are these two: MP3 and WMA.
Here is a link to all of the specs on your purchase: http://reviews.cnet.com/digital-photo-frames/coby-dp-5588-digital/4507-13499_7-32792849.html?tag=mncolBtm;rnav
Regards, Joe
PS please rate my answer. Thank you and happy holidays.
12/26/2009 4:37:05 PM • Coby DP-5588... • Answered on Dec 26, 2009
0answers
0answers
DP700 manual
Be the first to answer 3/18/2013 1:31:45 PM • Coby Photography • Posted on Mar 18, 2013Be the first to answer
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old. If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load. I would get it serviced at an aurgorised Minolta repair shop. Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM • Photography • Answered on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM • Photography • Answered on Mar 16, 2024
I lost one of the little rubber ball-like feet off my tripod 1612201. Do you have them available?
We don't have anything available Elizabeth. We are Fixya, and we only supply free information. It would be useful to know the maker as the '1612201' doesn't bring much up and looks like a serial number. Your local camera shop can get them, or you can get online. https://www.google.com/search?q=tripod+feet+replacement //
2/9/2024 6:10:43 AM • Photography • Answered on Feb 09, 2024
2answers
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file. img_20231124_190238_785-45plut3dk5rkrmoi0ue4e000-d-0.jpg
11/25/2023 1:11:02 AM • Photography • Answered on Nov 25, 2023
Coby DP-5588 5.6-Inch (4:3) Clock & Digital Photo Frame with MP3 Player (Maple) Logo
17 questions posted
Top Coby Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Coby Photography Expert? Answer questions, earn points and help others
View Most Popular
Coby Photography
  • Coby Photography
Most Popular Question
digital photo
  • Photography
