20 Most Recent Portasol 010389010 Heat Tool Kit Questions & Answers
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
3/18/2024 5:15:05 AM • Tools & Hardware... • Answered on Mar 18, 2024
Vibrapower Disc model BW-5040 exercise machine. E4 flashing on a Vibrapower disc model 5040. Replaced power cable
Question edited for clarity and typos. Question moved from Office Equipment category. It appears to be an unknown machine with no support and only mentions of people selling them. https://www.google.com/search?q=vibrapower+disc+5040+E4+error https://www.google.com/search?q=vibrapower+disc+BE-5040 A manual will often lead the the maker. https://www.google.com/search?q=vibrapower+BE-5040+manual ..
2/2/2024 1:34:19 AM • Tools & Hardware... • Answered on Feb 02, 2024
2answers
Where can I get replacement parts for my Tradesman BD460VM belt sander?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=Where+can+I+get+replacement+parts+for+my+Tradesman+BD460VM+belt+sander%3F
12/5/2023 10:35:53 PM • Tools & Hardware... • Answered on Dec 05, 2023
2answers
How to load a black and decker staple gun model dn418/d16
What width staples go in this gun ?
I have a box of T50 staples here labeled 5/16 , 8mm, but they are too narrow when dropped in to the channel in the stapler.
11/12/2023 6:22:42 PM • Tools & Hardware... • Answered on Nov 12, 2023
110v Milwaukee m28 battery charger was plugged into 220v outlet and not working
In this case, it's possible that the charger has been damaged and is no longer working properly. I recommend contacting Milwaukee customer service for further assistance. They may be able to help you troubleshoot the issue or provide you with a replacement charger if necessary. Here is their contact information: Phone: 1-800-SAWDUST (1-800-729-3878) Email: [email protected]
10/28/2023 7:18:44 AM • Tools & Hardware... • Answered on Oct 28, 2023
2answers
Removal Storage
If you are looking for a company who use latest equipments then i would refer you to appoint "bison removals" or "guildford removals". These two companies have excellent instruments to make your removal effortless.
10/4/2023 9:00:49 AM • Tools & Hardware... • Answered on Oct 04, 2023
Tacwise 191EL Pro Electric Nail / Staple Gun will not fire nails, it just clicks.
Question edited for clarity and toss in some CAPS. Usually caused by a jammed nail or staple. https://www.google.com/search?q=tacwise+191+el+pro+jam ..
9/19/2023 5:03:37 AM • Tools & Hardware... • Answered on Sep 19, 2023
Woodtek WK-2 Shaper. Looking for a manual for it please.
Question edited for clarity. No manual except with a used machine. The first link says who the distributor is. https://www.google.com/search?q=woodtek+wk-2+shaper+manual ..
9/13/2023 6:32:24 PM • Tools & Hardware... • Answered on Sep 13, 2023
I have a new staple gun but the handle won't go down it's stuck
no info generic answer is lock on --if not then bring back for exchange or refung
7/21/2023 1:56:06 PM • Tools & Hardware... • Answered on Jul 21, 2023
How to remove timing pulley bearings on 100-1598 enco mill
To remove the timing pulley bearings on a 100-1598 Enco mill, follow these general steps:
  1. Disconnect Power: Before working on the milling machine, ensure that it is powered off and disconnected from the power source. This is crucial for your safety.
  2. Remove the Timing Belt: Loosen the tension on the timing belt by adjusting or releasing the tensioning mechanism. This will relieve the tension on the pulley and allow for easier removal. Carefully slide the timing belt off the pulley.
  3. Remove the Pulley Retaining Nut: Using the appropriate tools (such as a wrench or socket), remove the retaining nut that secures the pulley onto the shaft. Turn the nut counterclockwise to loosen and remove it.
  4. Tap and Remove the Shaft: With the retaining nut removed, you can tap the shaft out from the opposite side of the pulley. Use a soft-faced hammer or a block of wood to gently tap the shaft, gradually moving it out of the pulley and bearing assembly. Be careful not to damage the shaft or the pulley.
  5. Remove the Bearings: Once the shaft is partially or fully removed from the pulley, you can access the bearings. Depending on the specific design of your Enco mill, the bearings may be press-fit or secured with set screws. If they are press-fit, you may need a bearing puller or a suitable tool to remove them. If they are secured with set screws, use an appropriate tool to loosen and remove the set screws before extracting the bearings.
  6. Install New Bearings (if necessary): If the bearings are damaged or worn, it is recommended to replace them with new ones. Ensure that you select the correct size and type of bearings for your specific mill model. Follow the manufacturer's instructions for proper installation of the new bearings.
It's important to note that specific procedures and techniques can vary depending on the exact design and construction of your Enco mill. Always refer to the mill's user manual or consult with a professional technician for model-specific instructions and safety guidelines. If you're unsure or uncomfortable performing these steps yourself, it's best to seek assistance from a qualified technician or machinist to avoid potential damage to the machine or injury.
7/15/2023 2:10:12 PM • Tools & Hardware... • Answered on Jul 15, 2023
2answers
How to load a Tangible LT-227 stapler please?
Question edited for clarity. This is a made in Taiwan special and a copy of an Arrow stapler. The staple magazine is the silver piece at the bottom rear edge. From memory, you press in and lift to unlatch it and then withdraw the spring and feeder. Link to the model, the maker and a video of a similar stapler. https://www.google.com/search?q=Tangible+LT-227 ..
4/9/2023 2:36:20 PM • Tools & Hardware... • Answered on Apr 09, 2023
2answers
Neiko 7 Auto Polisher. I need a user manual for it please?
Made in China and sold under different names. https://www.google.com/search?q=neiko+7+auto+polisher+manual ..
4/5/2023 4:12:02 AM • Tools & Hardware... • Answered on Apr 05, 2023
Need user manual for Neiko 7" auto polisher
Is this https://multimedia.3m.com/mws/media/758876O/3mtm-electric-variable-speed-polish-instr-man-7-1000-3000rpm.pdf
4/4/2023 7:19:04 PM • Tools & Hardware... • Answered on Apr 04, 2023
Do you sell the collets for the sharpener
Sorry but we do not buy or sell on this website. This is a site for repair advice and tips. Perhaps you could contact the original manufacturer of the sharpener or the place you bought it from. They may be able to supply parts or suggest where you could get them from.
3/27/2023 3:00:29 PM • Tools & Hardware... • Answered on Mar 27, 2023
2answers
I have a Skil Belt
Seven years later... sorry, man!— Solution — I have a Skil Belt Sander model 7313 which must be very similar if not the same. It has a 3/4HP motor, 3" x 18" belt capacity, a lever for belt release and a single Phillips screw for "adjusting auto-track" which is a misnomer in itself. Very odd. That screw is on the front left as you are using the sander, belt-down. When you "loosen" (CCW) this screw, the belt should move (if at all) toward the body of the sander; "tightening" it (CW) changes the angle of the front roller, which can force the belt off the open side. In my case I had to loosen it all the way just to slow it from slipping off the machine.My tolerances wore over time — or my belts were constructed poorly — so that the belt always rode off and away from the machine no matter where that screw was .So, I "shimmed" the roller closest to the adjustment with a 1/2" strip of duct tape one full wrap around (this made the end of the roller closest to the tracking adjustment "fatter." Tested it. It needed more. I added another piece of tape to the complete circumference of the roller, but this time 1" wide, covering the first tape right up to to the original edge, and over toward the middle. Tested it again. It needed more, but was improved. I added one more tape, 1-1/4" wide from the same edge out to the middle — effectively making a bit of a 'cone' toward the center, and this solved it for me. I think that in my case, the belts I bought at Home Depot were just a bit too long and needed this shimming method to take up slack. I found it easiest to make final adjustments "under load." Sand something right-handed using light pressure and adjust the screw with your left hand. (Note: this differs from the offical instructions in the manual: https://www.manualslib.com/manual/132374/Skil-7313.html?page=8.It may help to lubricate the pivot point of the front roller, which is actually about 4" back of the axel, right at the release lever's rivet, back inside the machine. If this pivot point is not fee moving, your auto adjust may not be able to allow proper rocking for adjustment.Also, with the belt off the machine, you can get a better idea of how the adjusting screw for the so-called auto-track feature does its work. Mine seems to have a lot of room to adjust it exactly the wrong direction, and no adjustment in the opposite direction. Hence my shimming idea.
3/2/2023 8:14:05 PM • Tools & Hardware... • Answered on Mar 02, 2023
Portasol 010389010 Heat Tool Kit Logo
0 questions posted
Top Portasol Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Portasol Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Portasol Tools & Hardware - Others
Most Popular Question
toledo 800 bets sander c ou ld ask size
  • Tools & Hardware - Others
