20 Most Recent
Sony Ericsson HCB-100 Wireless Headset Questions & Answers
User manual for sony ericsson
You can download and print the instruction manual in PDF format by clicking this
link.
Please note: Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using
FixYa.
Sony Ericson 250i Headset not recognised
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
19 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
