20 Most Recent
Logitech Internet Chat Headset with Microphone and interchangeable colours 980158-0914 Headset Questions & Answers
Logitech internet chat headset problems
No real easy way to fix this the sound thingy is very very sensitive and the slightest move to it could mess it up but a great head set I use is Skype they work great and the one I got cost 16 bucks and its comfortable and works perfectly..
So no real way to fix without damaging sound even more so buy a new one..
11/27/2008 5:26:35 AM •
Logitech...
Answered
on Nov 27, 2008
I have just bought
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected.
Hope this helps.
Headset malfunctioned and now connect
I believe this is a Bluetooth headset, have you tried replacing the batteries? If yes, try to delete the existing Bluetooth connection and try to create/add a new connection. 70% chance it will work, if not, the headsets need to be replaced.
Hope this helps.
