20 Most Recent
British Telecom Jabra BT2010 Wireless Headset Questions & Answers
Hi i have a jabra 2010 i have paired it with my
there is a menu in your ps3 (maybe audio devices or something) that you need to check. Make sure input and output are both on bluetooth headset. Mine was set to off, so mine wouldn't go for a while too! Just look around you will find it
I don't know what my
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
LED light is inconsistent
To pair the device you need to press it long so the LED is constantly lit ...
Make sure that you have turn the headset off first to enable pairing ...
The pass key at default is 0000
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
