20 Most Recent
Acoustic Research HD510 System Questions & Answers
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
2/4/2014 12:34:13 AM •
Acoustic...
Answered
on Feb 04, 2014
Makes a loud humming noise when plugged in, even when it is not conncted t the AVR
Humming noise could be an indicator of bad capacitors in the amplifier. You can take the amp out, pull the cover off, and look at the capacitors. If they appear to be swollen at the top, with some brown ooze coming out of them, then they need to be replaced. You can actually do this yourself from radio shack parts, just get the proper sized voltage and uf capacitors, desolder the old ones, and solder the new ones back in.I have to do this every 5 years, or so, to my old MTX home sub amp.
7/10/2012 11:41:44 PM •
Acoustic...
Answered
on Jul 10, 2012
I have a pair of acoustic research "active
DC 12v adapters are common and I think that would work. The similar "Powered Partner" speakers used a 14v DC adapter. Just check the size of the plug and the configuration (center pin is +). Radio Shack and other sellers have universal adapters.
12/2/2015 9:14:45 PM •
Acoustic...
Answered
on Dec 02, 2015
Subwoofer wont power auto on
your question too brief, no one can help. be more details so that can understand on your problem. or else there may have too many possibility to cause the problem happen.
2/4/2014 12:03:01 AM •
Acoustic...
Answered
on Feb 04, 2014
