20 Most Recent Jamo SUB 200 Subwoofer Questions & Answers
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Jamo SUB 200... | Answered on Oct 28, 2013
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Jamo SUB 200... | Answered on Sep 13, 2012
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Jamo SUB 200... | Answered on Aug 26, 2011
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Jamo SUB 200... | Answered on May 08, 2011
YOU NEED TO PLUG THE RCA INTO THE SUBOUT FROM THE AMP,THUS YOU ONLY USE 1 CABLE FOR THE SUB
Jamo SUB 200... | Answered on Apr 14, 2011
Phase reverses the polarity of the driver so it can be matched to the other speakers and bass-reinforcement characteristics of its position in the room. You don't want the sub 'sucking in' while other speakers are 'pushing out' or a bass cancellation will occur.
Set it, listen to bass from your normal seating position, reverse it and observe if the bass gets subjectively better. Leave it in the 'better' position.
Cutoff is a variable for the highest frequency where the speaker 'cuts off'. You can experiment with adjusting it for what sounds to you like the smoothest transition betwen the sub and the othere speakers. You don't want a lot of audible overlap where the sub and other speakers are acting on the same frequencies. It may sound to bassy in that area.
Jamo SUB 200... | Answered on Dec 26, 2010
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Jamo SUB 200... | Answered on Mar 03, 2010
Jamo SUB 200 Subwoofer Logo
20 questions posted
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jamo Audio Players & Recorders
Most Popular Question
phase cut off controls manual
  • Audio Players & Recorders
