20 Most Recent Behringer Eurolive B212A Speaker Questions & Answers
Hearing an air sound through speaker
Im having the same problem too. when i'm turning on the speaker, without having plugged some cable or jack on it, it sounds like blowing air (or like a storm).
10/24/2023 2:48:01 PM • Behringer... • Answered on Oct 24, 2023
3answers
Lost fuse and fuse holder for Eurolive B212A. Is the part available?
Either contact Behringer www.behringer.com where you will find the specifications, or buy a fuse and holder (you will need to buy the socket too) at any electronics component store. I found suitable fuses at au.rs-online.com (for Australia) Suitable fuse for Australia is T 2.5 AH 250 volt rating listed at $4.00 for the standard version and $64.47 for a fuse with IP68 (International Protection rating) For the US you would need the 5.0 amp version, same prices. You just need to check the socket design and compare with the products offered online for design compatibility. Cheers, Don.
8/13/2022 4:58:54 PM • Behringer... • Answered on Aug 13, 2022
0answers
How do I fix it?..
how are you hooked up? (hopefully you have this problem fixed by now. looks like you have 2 options for inputs. You can use xlr or 1/4" Are you hooking up to a sub as well or just flying these solo? Make sure your mixing board master is up, channel on mixing board is up, plug volume on speaker is up.. Im curious if you did get these fixed. Personally, I use qsc.. 26029540-rpqltah4fv1m3mnct1w42zea-3-0.jpg
1/4/2017 3:43:39 AM • Behringer... • Answered on Jan 04, 2017
2answers
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
6/22/2016 7:10:48 PM • Behringer... • Answered on Jun 22, 2016
2answers
Behringer monitor lost bass
You should check the woofer's impedance as a starting point, let me know further.
3/20/2016 8:36:13 PM • Behringer... • Answered on Mar 20, 2016
2answers
Behringer monitor lost treble
First and formost check the connections and ensure no stray strands between cables are touching, also the surface of the speaker is not been damaged
3/20/2016 8:34:29 PM • Behringer... • Answered on Mar 20, 2016
2answers
Behringer B215A replaced volume level knob does not respond.
You DON'T replace the board. If it is cracked, you bridge insulated wires around the cracks and epoxy them down.
Often the pads break from the traces near the pots. Look for a small crack between the pad of the pot and the circuit trace leaving it. Common problem.
6/15/2015 11:04:30 PM • Behringer... • Answered on Jun 15, 2015
I have a Behringer b215a
Were the fuses blown when you took them out? Did it blow the new fuses too? If so, your internal amps are fried. They can be fixed by a technician.
6/8/2015 1:24:35 AM • Behringer... • Answered on Jun 08, 2015
Behringer Fuse Holder for B212A
I realize this is an old question, but if anyone else has the same query, from page 6 of the manual listed below, the fuse holder is located on the back panel between the power on switch and power socket. For use on 120v supply, 5 amp/250v. For use on 240v, 2.5 amp/250v. -Steve http://www.behringer.com/assets/B212A_P0261_M_EN.pdf
3/9/2015 7:18:54 PM • Behringer... • Answered on Mar 09, 2015
Diaphragm replacement parts
Hi Here's the list of authorized Behringer dealers which should be able to help you out. -Steve Find Service Center
1/19/2015 2:53:07 PM • Behringer... • Answered on Jan 19, 2015
Where can I dowload the user manual
Here is the link to that manual. http://www.behringer.com/EN/Products/B212D.aspx
1/2/2015 5:32:13 PM • Behringer... • Answered on Jan 02, 2015
2answers
Tda7293 IC in behringer b215a keeps blowing, whats the cause?
Problem in the part of the power supply that feeds the tweeter amp. Fix the power supply and epoxy the board where it needs to be epoxy. Best of Luck! Serge Lavallee.
10/20/2014 10:56:16 AM • Behringer... • Answered on Oct 20, 2014
The piece that holds fuse broke
You can mke one. In stores, they sell little fuse holder with a wire at each end. It should replace it if you don't know how to do it, ask a friend who knows how to fix it. It is easy to fix. Best of luck. Serge Lavallee.
10/14/2014 5:00:34 AM • Behringer... • Answered on Oct 14, 2014
3answers
I open my b212a and disconnected the speaker and horn wires and know i have completed my repair i am read to reconnect and i don't remember which set of wires are the positive side
Because the system is bi-amplified, it is important to replace the wires correctly to avoid phase problems. I don't know how the wires are colour coded, but if it is any help I downloaded the schematic and the wires are numbered 1: Woofer Active 2: Woofer Earth 3: Tweeter Earth and 4: Tweeter Active. Sorry if that's no help. Otherwise it should be easy to trace the wires to see which connect to earth.
10/14/2014 4:56:21 AM • Behringer... • Answered on Oct 14, 2014
Remove woofer from behringer B215A
you want a woofer replacement? ... it's possible but you need to put whole your speakersystem in a program and the change you get the values you want is slittleeee. No if you need to ask if you have to change.... noooooooo. It's to complicated and only can ve done by peoples with real knowledge....
9/7/2014 7:53:20 AM • Behringer... • Answered on Sep 07, 2014
Berhinger IQ-12 2500w 12" 2-way speaker system
Fix Ya?????? come back when you buy a pair that won't work.
9/7/2014 7:49:26 AM • Behringer... • Answered on Sep 07, 2014
Amplifier blown.
Pls tell me why you think it's blown and just watch the partsnumbers with are stuck..... easy fix, totally no need to buy a whole need amp
9/7/2014 7:28:51 AM • Behringer... • Answered on Sep 07, 2014
If I can only buy the empliflyer
your question.? Well then you have a simple amp with your collection
8/21/2014 4:22:32 AM • Behringer... • Answered on Aug 21, 2014
Lost fuse holder for Eurolive B212A. Is the part available?
electronic parts store
8/21/2014 4:20:22 AM • Behringer... • Answered on Aug 21, 2014
Behringer Eurolive B212A Speaker Logo
97 questions posted
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Behringer Audio Players & Recorders
Most Popular Question
dowload user manual
  • Audio Players & Recorders
