20 Most Recent
IBM 92P6569 DVD/CD-RW for ThinkPad R50, R50e, R50p, R51, R52, G40, G41, T60, T60p Notebooks Questions & Answers
I have a peculiar problem. when i use the wifi
Are you sure your device is properly connected to your wifi? i mean are you able to browse google with it?
Because it seems your device is not really connected to wifi or getting a limited connectivity.
Ibm t60 2007 5u no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if you dont have a motherboard disk you will have to download the drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it righthope this helps
NO STANDBY MODE WHEN CLOSING LID
hmmm is the button on the computer that lid touches working ok?might want to manually test that with finger tip to determine if it's working
Wifi
No Speeka English???
Laptop ibm t60 screen white,
Check your laptop's LCD connections. One of the below items may need replacement or you may need to just reinsert them, might be loose.
- LCD cable
- LCD inverter
- LCD itself
NOTE: Most often, the LCD inverter is the culprit.
Hope this helps.
Bottom half of laptop screen
Try to hook up an external monitor just to check that it is not a problem with the video card of the laptop. Most likely the LCD cable is loose or the LCD inverter needs to be replaced.
Hope this helps.
POWER IS NOT ON, adopter
- There is a possibility that you have a bad battery or the problem is the motherboard.
- If you connect the charger and your thinkpad power on the problem is the battery but if, the charger is connected and still not powering on there is a possibility your board is crash.
- If you have other questions feel free to reply to this solution.
I’m happy to assist further over the phone at
https://www.6ya.com/expert/ramy_d9e7ebea3891f482
When turned on it starts up through to opening
I would suggest taking it to a repair shop and asking them to perform a "MEMTEST" the chances are that one of your memory modules has failed. Usually you would have two modules inside a pc or laptop. if one of them fails it stops everything from working. You probably just need to replace one of them at a cost of around £20 - £30 and this will usually resolve your problem.
When i insert new Ram
The problem is the RAM you inserted into the computer. Your laptop supports DDR PC2700. It will not work with DDR2 or DDR3. If it is not, you will need to get a different type of memory. If you have used the correct type of memory and it is inserted snugly, it is likely the RAM is defective, and you should return it.
I have 2 ibm thinkpad R50p. one is constantly
the one constantly shutting down may have heat issues. check that the fan and heatsink are not clogged.
the one messing with your radio all the time must be having a wireless RF interference problem or something. Try turning the wifi off and plugging it in with a CAT5 cord.
