20 Most Recent
Toshiba Satellite A205-S5812 Notebook Questions & Answers
Network Driver Issue/Internet Connection issue
you can try a couple of things, on the back of the router is a small reset button, you will need a pen or pencil to push this button, hold it in for 10 sec. or so, until the router resets, and try to connect then, or unplug router, leave off for 10-15 sec. plug back in and wait fir it to reset this way, or a more involved way is to go to your DOS or command prompt window, type in this as follows
ipconfig /release
(wait a few seconds for this to do its thing)
ipconfig /renew
(if this doesnt work ask your parents if they put a block on the router)
8/12/2020 2:23:29 PM •
Toshiba...
Answered
on Aug 12, 2020
A205-S5825...Vista Home Premium Message comes up
Hiya..just my opinion..forget media centre, download VLC player..It will ask if you want it as your default media plater..Say Yes (it plays all formats) if that doesn`t solve the missing DVD player, update your drivers from the Toshiba site. Failing THAT..
Google " CD/DVD run repair" I have had the same problem and there are a few free programs to fix problems.
Just ideas of the top of my head . good luck Pete
[email protected]
10/13/2017 11:39:31 AM •
Toshiba...
Answered
on Oct 13, 2017
My password is bloqued I can't stand this anymore
If the boot password is set and you do not remember (?) it, you must take the machine to a Toshiba Service Center to have the password erased. It will cost you something if the machine is out of warranty. You may be asked to show proof of ownership.
10/20/2013 2:36:59 AM •
Toshiba...
Answered
on Oct 20, 2013
Screensize changes size
Welcome to Fixya.
Go to your main screen then just right click, select properties, then go into settings and drag the screen resolution bar to the more side and select ok and hit yes when the little box comes up.
Please feel free to come back if this does not fix it.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
11/15/2010 12:14:36 AM •
Toshiba...
Answered
on Nov 15, 2010
DVD region default setting
Click Start - My Computer then Right click on the DVD drive - click on Properties - Click on Hardware tab - click on the DVD drive to highlight this drive then click Properties - then click DVD Region tab.
Now you can change the region.
It shows the current Region - Enter a new Region and click OK
If you have run out of Region changes, please let me know and I can advise you how to get around this problem.
10/12/2010 10:06:35 AM •
Toshiba...
Answered
on Oct 12, 2010
Will not power up.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
9/20/2010 1:05:54 PM •
Toshiba...
Answered
on Sep 20, 2010
Reset bios on toshiba a205-s5804
If I could know the Reason why do you need to do so wd be better.
but with Laptops, to reset Bios is not a good idea, better is to get them upgraded with the same version.
Else first try loading optimum defaults
9/20/2010 4:29:24 AM •
Toshiba...
Answered
on Sep 20, 2010
Esta bloqueada....olvide el password the bios
Open the memory cover under the laptop and locate 2 solder connections marked by XXX....place a small screwdriver on the 2 contacts while turning on the laptop and that's it.
5/28/2010 8:36:36 PM •
Toshiba...
Answered
on May 28, 2010
How i can remove Bios password from Toshiba
There is
NO way that it can be fixed OTHER than returning it to the manufacturers or
agent. They have proprietory Software Challenge Codes and this will do the job.
However they cahrge for this usually around $125. Also one must provide proof of
purchace and ownership. You can also find places online too, however they also cost.
5/28/2010 8:33:05 PM •
Toshiba...
Answered
on May 28, 2010
I have got a problem with my laptop i have forget
The simplest way to remove a BIOS password is to simply remove the CMOS battery wait for a few minutes and then put it back in, it will do that for you. Since you have a laptop it may be a bit difficult to do that as the CMOS is on the motherboard.
3/12/2010 3:58:21 AM •
Toshiba...
Answered
on Mar 12, 2010
