20 Most Recent
Jl Audio 12W6 Car Subwoofer Questions & Answers
Amp goes into protection mode
Sounds like you are running your subs at to low of ohm. Amps are rated differently on the levels of ohms or resistance that they can get to. If you have a dual 4ohm sub and run it in pairrell it will drop to 2ohm and if you run the same sub in series it will be 8ohm. Your amp will go into protection if the ohm is to low.
-david
I have 2 jl audio 12w6 and one jl audio 500/1 amp,
yeah you can always take it back to your local JL audio dealer, i wouldnt do it your self unless you done it before and got it down like a ****. A lot of people i know tryed and always ending up tossing it out.....
Who to wire JL audio 12w6 to its max
Hello shermalestuc,
The JL Audio 12w6 v2-D4 has dual 4 ohm voice coils that can be wired for either a final load to the amp of 2 ohms (parallel) or 8 ohms (series).
If your amp is 2 ohm stable, the best power solution for a single sub is to use the parallel configuration, both positives and both negatives together and then to the amp.
