20 Most Recent
Lenovo 3000 Y410 (59012354) PC Notebook Questions & Answers
Dvdrw drive not working
sounds to me like you are trying to read a dvd from a cd drive
if so you have to have a dvd drive in order to read the disk
cd drives do not support dvd drives unless they are cd/dvd drives
Lenovo y410 web cam drivers for xp
1. Try the Updated Windows XP Professional SP2 (verison 5.1.2600) to the most latest and greatest update
2. Trt to check if the camera is working .. If not,
3. Download the integrated camera creative drive from dell .. website . here's the link
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R160323&SystemID=XPS_M1330&servicetag=&os=WW1&osl=en&deviceid=15135&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=214676
4. Install the above driver, restart your computer
5. After restart press Fn+Esc key .. to enable the camera. (You should see a small pic icon on the right side bottom of the screen)
6. The hardware wizard will detect a new USB Webcam
*Note: The above link also works for lenovo. Please rate me if you already have the result.. thanks..
Best Regards
Does Lenovo 3000 Y410 support dual monitors
Yes.1) Laptop OFF, monitor OFF.Connect a VGA monitor to the VGA port, on the back of the laptop.The VGA port is on the right side, as you view the back of the laptop.This is a basic example of a VGA cable, and a VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connectorNOTE* Color does Not matter.You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.Turn the monitor on. If a CRT type allow it to warm up.Turn the laptop on.By default the display should show on the external VGA monitor.IF not;Press, and hold down on the Fn key, and at the same time tap once on the F3 key.No?There are at least 3 display options;1) Internal monitor of laptop ONLY2) Internal monitor of laptop AND external VGA monitor3) External VGA monitor ONLYHold the Fn key down, and tap again on the F3 key.(The Fn key is down at the bottom LEFT corner of the Keyboard.The F3 key is at the top of the Keyboard.The F3 key is the Display Toggle-Over key )Need more information post in a Comment.Regards,joecoolvette
Sir i am a dealing
your in windows xp and youre try to install sp3 from a disk i take it.
either the disk is corrupt,missing files or wrong version .causing blue screen.(fatal exception)
you could try leaving the disk in and reboot ...
when in windows select run D: or what ever letter is assigned to cd drive .( start , run , type in d: and enter)
this will show files on cd/dvd. drag and drop the .exe program into a file or on desktop and try to run.if it runs the cd/dvd is the prob (corrupt,virus,missing files.) if it does run its the software incompatable or faulty(incomplete files or wrong version)
either way the cd will be useless.
you can download sp3 (free)as long as you are using a registered os.
I could not found lenovo
I understand that camdriver is very important to a laptop for you to be able to do video call. But don't worry there's a site where you can download it for free. All you have to do is
click_here so that you will be directed to the exact site.
Once you click download, just follow all the prompts then you are good to go.
I hope you have a wonderful day.
My dvd player on recognizes
most of the laptop dvd drives have slower reading speed(about 2x) and writing speed(about 24x) compare to desktop pc's(about 8x and 52x respectively).
ur problem might have occured if the writing speed by which the cd was burnt might not be compatible with ur dvd player.
try playing dvds which were burnt using laptop dvd writers.
also try changing the modes in which the dvds are burnt.
My lenovo y410 integrated web
Lenovo 3000 Y410 is not designed for windows 7, I don't think that Lenovo will make drivers for windows 7, you can try to install the Vista drivers. here is the
link for 32 bit, they did not release any 64 bit drivers for this model. you can download and save the drivers to your computer then right click the installer then click properties, click the compatibility tab then select run this program in compatibility for Vista Service pack 2. If it still doesnt work you can try to run Windows update and hopefully microsoft have some patch for that.
Hope This help.
Describe how you insert a
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
My web cam is not
Welcome to Fixya
Make sure first the the webcam driver is properly installed. You can check that one by going to control panel then click system icon then go to hardware then click device manager. Your webcam should be listed under imaging devices. If it is not there then you may try to enable it by pressing Fn + Esc key.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Wireless adaptor doesnot work!!
Welcome to Fixya
Check the wireless adapter if the computer was able to detect the card. Go to contorl panel then go to system then click device manager. You should be seeing your wireless adapter under network adapter. make sure that there is no exclamation mark on your wireless adapter. If there is, all you need to do is to reinstall the driver of the wireless card.
Sir, my web cam is
Welcome to Fixya
Please check if you have the webcam in the device manager. You may try to reinstall the drivers of your webcam. You can also enable/disable the webcam by pressing the Fn + esc key.
Please let me know of any development.
