20 Most Recent Yale Security YRD220-NR-ORB Brz Touch Elec Deadbolt Questions & Answers
Beads for Necklace
Your question mis-categorized: Electronic Keyless Lock QuestionsResubmit if you want help.
4/7/2024 3:21:45 AM • Locks &... • Answered on Apr 07, 2024
2answers
I just bought your defiant electronic deadbolt. It works backwards ... Lock is unlock and unlock is lock ... I've been working this for 7 hours!
I would recommend taking the deadbolt back to wherever you purchased it from and exchanging it for a new one. It sounds like you got a defective unit.
Just so there’s no confusion, this website is a general question-and-answer site for anyone who needs help fixing something. It’s not the customer service website for the manufacturer or retailer you got your deadbolt from. I do not represent the manufacturer or the retailer. I’m just a random guy on the internet trying to help out. :)
2/23/2024 5:39:59 PM • Locks &... • Answered on Feb 23, 2024
How do I get replacement key for Nutool SF10 electronic digital safe
If it is not fixed to the wall , drop it on a bed holding the opening dial and as it bounces open it . It took me a couple of goes to get it right but it works
2/16/2024 1:16:05 PM • Locks &... • Answered on Feb 16, 2024
2answers
I have a Kaba e plex 2000. it will take a code and flash green but when you turn the handle the bolt does not retract.
img_20240204_162938-amvrdz0ilpspcrujrnrey3ag-d-0.jpg A friend had a similar issue with his lock. After taking the back plate off I found that silver arm that locks into the door handle cam had lost a tiny c clip and come apart. One I reassembled both parts of the arm on the retaining peg using the c clip and put the white spacer ring on top everything looked right. Reassembling the gear section while keeping the round handle return spring from popping off was challenging.
2/7/2024 1:36:37 AM • Locks &... • Answered on Feb 07, 2024
2answers
3answers
Factory code for a micro fridge electronic safe
I have a micro fridge electronic safe the 4 number does not work need hep
1/14/2024 12:05:51 AM • Locks &... • Answered on Jan 14, 2024
3answers
Combination lock won't close
While leaving the lock open, proceed through the combination. When you're done, stick a screwdriver or something similar in the hole and pry the locking mechanism back. Once it is out of the way you should be able to lock it again.
12/28/2023 11:37:40 PM • Locks &... • Answered on Dec 28, 2023
I have an open USCan safe, Model UC 913-B. Unfortunately, I have no instructions to use it. I see there is a reset button on the inside, but have no idea how to reset it.
There is a FB1913-E model here https://www.uscansafes.com/ca1/uscansafes_eng/fireandburglarysafes.php No Manual online, so click their Contact link and ask. https://www.google.com/search?q=uscan+safe+model+uc+1913-b+manual+pdf Normally you press the reset button and put the new combination in and it beeps. Always double check the combination works with the door open. Make sure to use a number you can't possibly forget. The Lock on this one looks the same? This one may be your safe?
12/23/2023 10:54:22 PM • Locks &... • Answered on Dec 23, 2023
Gordon digital electron safe #45891. Lost key.
You can open them faster with a rare earth puck magnet that you can putting the combination digits in. .. There are also this type of attack but the Lock Picking Lawyer shows the workings. The magnet pulls the solenoid in the same way. It is a low skill attack. ..
12/6/2023 10:35:39 PM • Locks &... • Answered on Dec 06, 2023
2answers
What kind of combination does a field and stream 1871 24 gun safe have. And can combination be changef
notify manufacturer or a locksmith
10/21/2023 3:46:51 AM • Locks &... • Answered on Oct 21, 2023
0answers
I have an H0822 Secustar Safe. The keys are locked inside & the battery is too weak to open the safe with my code. Any options?
Classic mistake keeping the emergency key inside the safe! It can be opened very easily in 10 seconds with a large rare earth puck magnet in a sock. They all work the same way using an electronic magnetic solenoid operated by the internal battery. The puck magnet does it externally. https://www.google.com/search?q=open+safe+with+puck+magnet. ..
9/12/2023 6:35:18 AM • Locks &... • Answered on Sep 12, 2023
2answers
Need help to reset thw codes in a Futura Safe Box?
9/6/2023 10:19:30 AM • Locks &... • Answered on Sep 06, 2023
Call serulc I can not put PIN
no info generic answer notify manufacturer or a locksmith
8/23/2023 4:53:43 PM • Locks &... • Answered on Aug 23, 2023
Can't remember combination to Brinks locking carabiner. It's opened but locked.
Look at the YouTube channel 'The Lock Picking Lawyer'. All his videos are short and sweet. All combination locks can be decoded with a feeler gauge or a thin piece of plastic. He will have opened this lock.
7/28/2023 1:10:17 AM • Locks &... • Answered on Jul 28, 2023
New Onity HT24 locks not showing up on Bluetooth?
Normally not telling the lock to find the phone https://www.fixya.com/support/r26362721-pairing_bluetooth_devices Other ideas here and Onity for Support. https://www.google.com/search?q=Onity+HT24+locks+not+showing+up+on+Bluetooth ..
6/2/2023 5:37:26 PM • Locks &... • Answered on Jun 02, 2023
Suresafe Digital Safe misplaced key
Well you put the code in and it opens. I guess you missed of the part where you ignored the 'Change Battery' notifications and the incessant beeping :>D Or has it just failed, found it in a skip, found it in a house, code written on the back? You can open it faster with a rare earth puck magnet than you can inputting the code. The word ;Safe; is a misnomer.
5/31/2023 2:53:18 AM • Locks &... • Answered on May 31, 2023
Yale Security YRD220-NR-ORB Brz Touch Elec Deadbolt Logo
0 questions posted
Top Yale Security Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Yale Security Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Yale Security Locks & Locksmithing
Most Popular Question
not able adjust leaking oil
  • Locks & Locksmithing
