20 Most Recent
Audiovox Jensen Universal iPod Docking Station with Full Scan Radio (JISS-20-BK) Questions & Answers
Ipod will play on tunebase fm but it won't charge
There are issues with newer ipods not being 100%compatible with all devices. It is done intentionally by Apple to maximize their profits. For example, an FM transmitter charges and plays on one Ipod, but then a newer ipod will play with the FM transmitter, but the ipod display shows that it is incompatible and will not charge. Same issues with a docking station and a radio. All worked with three other ipods, but the newer ones either won't work or charge depending on the device. Even though ipods play with certain devices they may not charge them and vice versa. Thank Apple for that. I hope this helps and good luck!
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
RCA th1611-A mp3 player not recognized by software
This item is a USB2.0 device. Older computers use USB1.0 and new computers USB3.0. Depending on your computer age, this may not be recognized. I suggest you make certain all USB device drivers are up-to-date.
