20 Most Recent
Ebac HD880 Dehumidifier Questions & Answers
I have an ebac homedry
I see by my computer this is a UK unit made for UK climates.
I also found various web sites you can access for help with your unit. Please explore these.
God bless your efforts.
We need a ebac 200e
Depending on what supplier you buy from you can expect anywhere from 20.00-60.00.I would recommend that you try e-bay.Sorry I can't be more help. Thank you
I have a Ebac Homedry
If it was frozen and is now thawing, you will probably find some water in the collection container and some on the floor.
My 880 home dry is
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
I HAVE A EBAC HOMEDRY 880 dehumidifier
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Replacement fan motor for ebac homedry 880
Noel
