20 Most Recent Fieldvision 114mm Reflector (114 x 114mm) Telescope Questions & Answers
7answers
Upside down images
As we all learned in grade school, telescopes produce an upside down image - it's okay for astronomical use since upside down doesn't matter. If you want an image like you'd see in a pair of binoculars, get an image erector from a telescope accessory store to add to your eyepiece.
9/6/2013 2:35:34 PM • Fieldvision... • Answered on Sep 06, 2013
Bushnell 114mm reflector telescope, can't see a thing
Probably NOT actually pointed directly at the moon-- you should have moved it around a little -- the moon was probably just outside the field of view through the eyepiece. ........................ telescope must be pointed DIRECTLY at the sky object-- also use the eyepiece with the largest number written on it=== this gives the LOWEST magnification..... and a slightly wider field of view.
1/22/2013 9:32:06 PM • Fieldvision... • Answered on Jan 22, 2013
Fieldvision 114 mm reflector instruction manual
Sorry there are no specific manuals for this small imported relector style telescope. Use one of the Bushnell manuals for reflectors on this page-- they all work the same way.
http://www.opticsplanet.net/bushnell-warranty.html
7/9/2011 2:23:40 PM • Fieldvision... • Answered on Jul 09, 2011
How do I fix the
Astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear.
It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one, but if you want a telescope primarily for terrestrial use, you are much better off buying what is called a "spotting scope".
If the telescope has a standard 1.25 inch diameter eyepiece, then an erecting eyepiece may be found on Amazon or eBay. An erecting prism or diagonal of the type that bends the light through 90 degrees is not right for a reflecting scope. These are used on refractors.
6/6/2011 5:23:38 PM • Fieldvision... • Answered on Jun 06, 2011
Model# 100501103 I need a new manual with
Sorry ut you will not find a manual for that small telescope. It's a reflector style telescope probably on an equatorial mount which must be polar aligned in order to be used.
Here is a Meade brand manual that is similar to your scope:
http://www.meade.com/manuals/TelescopeManuals/Reflectors/Meade4500.pdf
12/21/2010 2:41:46 PM • Fieldvision... • Answered on Dec 21, 2010
I HAVE A NEW TELESCOPE,
You are doing nothing wrong. Astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear.
It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one.
12/2/2010 5:12:24 PM • Fieldvision... • Answered on Dec 02, 2010
Where do i find a
This is an eyepiece attachment that goes in between eyepiece and telescope. I found only two items on ebay.com (different size/fit), searching on "eyepiece erector".
11/22/2010 2:50:51 PM • Fieldvision... • Answered on Nov 22, 2010
Where can I buy a erecting eyepiece for my
Many on line sites sell these: here is one:
http://www.astronomics.com/main/Image_Erecting_Prisms.asp/catalog_name/Astronomics/category_name/EDNECFUVSRWS8KLNTU5E38XSE1/Page/1
11/11/2010 5:17:22 PM • Fieldvision... • Answered on Nov 11, 2010
I purchased a Rokinon Refractor 900mm x 90mm and
This is an imported telescope probably from China. You will not be able to contact a manufacturer. Never buy a telescope off of Ebay, at a garage sale, from Wal Mart, or craigslist, unless you know exactly what you are buying.
Buy from either a local telescope shop or online from reputable retailers like these:
http://www.meade.com/locator/
Your scope appears to be on an equatorial mount which must be polar aligned in order to be used. Google "polar alignment" and learn how this is done or read my TIPS on my profile page.
Eyepieces come in 3 sizes .975, 1.25, and 2 inch. Measure the hole in the focuser. Any of the retailers listed above can sell you an eyepiece.
Also log on this web site and read the forms-- for lots of information:
http://www.astronomyforum.net/
11/2/2010 1:07:10 AM • Fieldvision... • Answered on Nov 02, 2010
Need a manual or a phone number for the company
As you can see from the ONE review here:
http://www.dealtime.com/xPR-Fieldvision-Fieldvision-114-mm-Reflector
A manual does not exist for this imported telescope. This is just one of DOZENS of brands imported from China.
It is a reflector style telescope on an equatorial mount. The mount must be polar aligned in order to be used.
Google
Polar Alignment
Reflector Telescope
Equatorial Mount
You will find hundreds of articles on how to use this telescope. Read my TIPS on my profile page and also read this web site:
http://www.texasastro.org/telescope.php
8/13/2010 3:11:40 PM • Fieldvision... • Answered on Aug 13, 2010
My telescope images are upside
ALL astronomical telescopes show upside down images, it's normal. Nothing is wrong with your telescope.
For terrestrial viewing you can buy an "erecting prism" which will turn the image right side up.
Like this one:
http://www.skiesunlimited.net/index.php?CategoryID=98
Read my Frequently Asked Questions TIP on my profile page.
8/3/2010 6:15:21 PM • Fieldvision... • Answered on Aug 03, 2010
Upside down images on my telescope. Bought used -no manuel. What to do?
In a refractor images are upside down as with most telescopes. You need an image erector to create a normal correct R and L and Up and Down image. It is a lens which goes in front of the eyepiece to give a correct image.
6/2/2009 3:44:32 AM • Fieldvision... • Answered on Jun 02, 2009
4.5 inch reflector telescope --can't see anything
you have to make sure your primary mirrow is level, there are a set of screws that will help you do it, then the secondary mirrow at 45 degree, start in a daylight to align the telescope. good luck
12/2/2008 9:43:41 AM • Fieldvision... • Answered on Dec 02, 2008
Why is everything upside down
All astronomical telescopes show the view upside down. it is the properties of the mirrors/lenses. Ther is no up and down in space. You will get used to it.
For terrestrial viewing, you can buy a erect image diagonal (for refractors and SCTs) or a erect image eyepiece for refractors. This is not recommended for astronomy since it reduces contrast.
10/18/2010 12:34:36 PM • Fieldvision... • Answered on Oct 18, 2010
3answers
How do I change Language on a sokkia set 250x total station
hi deshwashin error vod d13 brandt thnks
4/4/2024 7:00:30 AM • Optics • Answered on Apr 04, 2024
Need manual for edu science star tracker telescope
Yes I do
1/13/2024 1:28:24 PM • Optics • Answered on Jan 13, 2024
Tascos riflescope 3x9x50 adjutment caps
Visit your local gun shop and have them order them.
10/17/2023 10:13:50 PM • Optics • Answered on Oct 17, 2023
I need firing order for a 1981 Johnson seahorse 115
its just 1-2-3-4- with the port bank being 2-4 starting at the top and the starboard side being 1-3. They're all the same be it V-4 or V-6. 6=123456 60* and 90* are the same
5/31/2023 9:13:49 PM • Optics • Answered on May 31, 2023
Fieldvision 114mm Reflector (114 x 114mm) Telescope Logo
Popular Tags
15 questions posted
Top Fieldvision Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Fieldvision Optic Expert? Answer questions, earn points and help others
View Most Popular
Fieldvision Optics
  • Fieldvision Optics
Most Popular Question
fix
  • Optics
