20 Most Recent Yukon NVB Viking 3.5x40 RX Questions & Answers
Hello, clean the outside of the lens with a good optical cleaner. If you have, then trying adjusting the focus for each eye. Try both ends of this binocular at one eye at time; such as, left first, then the right eye until there are focused. That is if you can focus the optical end and they leave you with the eye lens for focus. Let me know how it works out. stewbsion
Yukon NVB Viking... | Answered on Aug 15, 2011
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Yukon Optics | Answered on Sep 24, 2011
put a dead mouse on it
Optics | Answered 15 hours ago
he i need a tripod to reflector telescop 525
Optics | Answered on Apr 14, 2019
We do not do appraisals.
We can't see what you have can we and it would be impossible to guess. All the models are pictured in the link
https://www.google.com/search?client=firefox-b-d&tbm=isch&q=springfield+precise+time
Optics | Answered on Apr 13, 2019
If it is a S&W, you will have to call them. They were sold on the M&P 15-22 Sport as part of a promotional package.
Optics | Answered on Apr 11, 2019
Yukon NVB Viking 3.5x40 RX Logo
1 questions posted
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
right eye blurey dirty
  • Optics
