20 Most Recent Hunter 30124 Air Conditioner Questions & Answers
The air conditioner has a flashing red light on
Is the compressor running? If blowing cold air while on heat setting the reversing valve is not working.
9/1/2017 4:18:52 PM • Hunter 30124 Air... • Answered on Sep 01, 2017
Why won't thermostat turn on after I changed the batteries?
I think you may have the model # incorrect, However if you have a thermostat as in the type that are hand held, polarity of the batteries is the 1st thing I would check, then test them for proper voltage, corrosion will often interrupt that small of a voltage, clean the terminals and test it . A wall mounted like a central HVAC system typically will not require batteries to operate, this is for memory and they will work fine even if no batteries are installed, however there are battery powered stats too, meaning non parasitic type that not powered by the transformer in the air handler. I will include a basic drawing of a residential HVAC thermostat to show you how the 24 volts powers most thermostats. ome > Air Filtration > Air Cleaners and Purifiers > Hunter Air Purifiers > Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer Item #: hun30124 892f1d0d-b50f-49aa-8079-70d2dc34eb2b.png
6/7/2014 2:58:59 AM • Hunter 30124 Air... • Answered on Jun 07, 2014
Heating Model 44360
you should have a 'hold temp' option on your remote, it should then stay at the set temp until you change it
3/1/2014 12:29:25 PM • Hunter 30124 Air... • Answered on Mar 01, 2014
Hunter thermostat problem
I can't see a thermostat for the reference given (30124). According to my listings that's an air conditioner.
I do have the manuals for Hunter - Just click HERE for a list to the PDF documents you can download and print off.
Thanks for using Fixya, If it has solved your problem, please rate as such. thank you.
2/9/2014 10:49:56 PM • Hunter 30124 Air... • Answered on Feb 09, 2014
Fiberglass bubbles in sides of rv
Moisture has got in to laminated panels. Seal anything near it weel as that is most likely place that moisture entered. Window, molding, door, water heater, furnace etc near it'?
11/2/2013 12:48:01 AM • Hunter 30124 Air... • Answered on Nov 02, 2013
0answers
My 1993 honda civic air conditon does not get cold when the weather is hot
Look at the cooling fan it shod come on when the ac is on if it dose the look at the 134A
8/17/2012 6:15:42 PM • Hunter 30124 Air... • Answered on Aug 17, 2012
How do i get a licence to buy freon
Hello, there is a examination you must pass in order to purchase refrigerant. There are many differant organizations that provide testing such As RSES or your local Heating amd Cooling supply store.
6/13/2012 2:13:37 PM • Hunter 30124 Air... • Answered on Jun 13, 2012
2answers
We've turned on and set
Kinz, there are several things to troubleshoot,
1. Check the air intake filter for dirt or clogs.
2. While you have the front off to remove the filter, look at the cooling coils to see if they have frosted over. If so, turn the unit OFF,Unplug it and allow it to thaw completely. Once it has thawed, clean the coils, by wiping them with a damp rag of luke warm water. Dry them as best you can and what you can't reach, allow to air dry. Then spray a light coating of WD40 on them. Also check the cooling fins. If they are dusty, use a vacuum cleaner that has a hose and brush attachment to clean them. Reassemble all the parts, plug the unit back in, turn the Master ON/OFF Switch to ON and set your thermostat to the temp you want to maintain. Give it about 30 minutes to run, before checking it again. Hopefully, this solved the problem.
If not, worse case scenario is, one of the condenser circuits has failed and needs to be replaced. Or the compressor is low on R14 refrigerant gas and needs to be recharged. Either one should be checked and repaired by an authorized service technician, because it requires the proper equipment to service and repair those two things.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
6/1/2012 1:12:56 AM • Hunter 30124 Air... • Answered on Jun 01, 2012
Wiring mdel 44155c
what wire goes where on new thermostat my wire on old thermostat are red, white, green, and blue ro could u please tell where to connect them on this new thermstat.
9/1/2011 12:25:56 AM • Hunter 30124 Air... • Answered on Sep 01, 2011
0answers
2answers
Thermostat control
I would like some help programing the thermostat in my house. Hunter, Model 44300A
Thanks,
3/19/2011 3:30:59 AM • Hunter 30124 Air... • Answered on Mar 19, 2011
I have a digital Total
Normally Red to R (24v coming to stat) White to W (Heat) Green to G (Blower)
Yellow to Y (Air conditioning) Blue to C (common)
This is assuming you have gas heat and central air conditioning. If you have a heat pump blue would be for that. If you have a volt meter, check voltage between red and blue with furnace turned on. It will be 24 volts approx. if blue is common.
1/17/2011 6:25:31 PM • Hunter 30124 Air... • Answered on Jan 17, 2011
2answers
Don't know if the problem
This sounds like a bad thermostat, but it could be a bad heating coil, if that's what they use in this unit. You can get parts for it at SearsDirect online:
http://www.searspartsdirect.com/partsdirect/part-model/Hunter-Parts/Air-conditioner-heat-pump-Parts/Model-ALLMODELS/0525/0904000
Since Sear's has sold and serviced this brand, I would call a Sear's Appliance Center and see what they think the problem is. They usually know, or have a good idea, of what's failing, since they're the ones that deal with it.
If you're handy with a voltmeter, you can check the output of the thermostat, and if it's good, then ohm out the coil, or check for a thermocouple, if the unit has one.
I read that they do have a 1 year limited warranty, so you might check into that, if applicable.
Good luck, and hope this helps.
1/11/2011 11:24:08 PM • Hunter 30124 Air... • Answered on Jan 11, 2011
We locked are and we need a overide code to reset
mcdevito75 here, Try to contact Hunter A/C online or by phone.
6/25/2010 11:25:17 PM • Hunter 30124 Air... • Answered on Jun 25, 2010
Hunter 30124 Air Conditioner Logo
40 questions posted
Top Hunter Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Hunter Heating & Cooling
Most Popular Question
39 ve turned set
  • Heating & Cooling
