20 Most Recent Yellow jacket 93560 SuperEvac 6 CFM Vacuum Pump Questions & Answers
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
I need the spray head diverter that spreads out the spray - it snaps onto the front end.
Posted to Home Plumbing category, so one of these https://www.google.com/search?q=vintage+sprayer+spray+head+diverter Or Garden Sprayer like this? You can get a vintage new wand on eBay. https://www.google.com/search?q=vintage+garden+sprayer+nozzle All questions need FULL 'make model (what is is)' as first 3 words. ..
11/26/2023 12:59:53 AM • Plumbing • Answered on Nov 26, 2023
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets. Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
11/18/2023 1:01:01 AM • Plumbing • Answered on Nov 18, 2023
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM • Plumbing • Answered on Oct 28, 2023
2answers
Acrylic sheet
Hello. You can heat it up with a torch along the bend line and bend it. Be careful as it get HOT. Joe
10/19/2023 9:44:08 AM • Plumbing • Answered on Oct 19, 2023
My Mirolin bath drain stopper had a spring, which went down the drain when I removed the stopper to clean. Now I'm not sure how the new spring I bought goes back on.
This seems like a system which is proprietary to them, so best to ask their Support staff https://mirolin.com/contact-us/ You could have retrieved the old spring with a flexible magnetic reach tool. https://www.google.ca/search?q=magnetic+pickup+tool https://www.google.com/search?q=Mirolin+bath+drain+stopper ..
10/10/2023 11:30:47 PM • Plumbing • Answered on Oct 10, 2023
Kitchen sink hose broken button nozzle
9/14/2023 5:02:50 AM • Plumbing • Answered on Sep 14, 2023
How do i fix getting water to come out of the faucet ?
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
9/12/2023 6:09:20 AM • Plumbing • Answered on Sep 12, 2023
Gnutti Sebastiano thermostatic mixing valve 1559-6I. Where can I get a new one please?
Question edited for clarity. Question moved to plumbing. Not a very well known brand. It has TWO Employees!! https://www.datanyze.com/companies/gnutti-sebastiano-figli-spa/25986208 Try here. They are U.K. based.
Thermostatic Cartridge for GS Groupo Gnutti Sebastiano ...
Di Vapor https://www.divapor.com > thermostatic-cartridge > th... Thermostatic Cartridge for GS Groupo Gnutti Sebastiano 7421 For All Thermostatic Mixing Valves - Small 20 Pt Stem. Part Number: GS-7421. Price: £199.95. £149.83 More here https://www.google.com/search?q=%22Gnutti+Sebastiano%22+thermostatic+mixing+valve ..
8/19/2023 2:47:11 PM • Plumbing • Answered on Aug 19, 2023
Hamilton Beach stand mixer 63391 repair.
The aim to keep screws invisible so in many cases you have to start at the base and work up. https://www.google.com/search?q=hamilton+beach+63391+dissassembly No Service Manual for it https://www.google.com/search?q=hamilton+beach+63391+service+manual ..
7/20/2023 2:53:20 PM • Plumbing • Answered on Jul 20, 2023
My customer has a leaking unit and I suspect it is missing a cap? Can you confirm for me this should be a closed with a cap like the other side?
and RV toilet sewage pump? no RV told, zero, facts useful
5/4/2023 11:18:00 AM • Plumbing • Answered on May 04, 2023
Tuscany Kitchen Faucet Kendre model 673-6070. Removing the handle on the one handle pull-down kitchen faucet model 673-6070?
Question edited for clarity, full 'make model (what it is)'. This a Menards special. To remove handles, look for a small hole hidden from the front. They take a small Allen Key.
tuscany kitchen faucet kendre model # 6736070
Complaints Board https://www.complaintsboard.com > ... > Menards Mar 2, 2023 - Consumer complaints and reviews about Menards Ballwin, Missouri. tuscany kitchen faucet kendre model # 6736070. Building & Construction. Pros and cons: Sprayer does not spray ? View full list https://www.google.com/search?q=kitchen+faucet+model+673-6070+replace+cartridge
4/29/2023 12:56:17 AM • Plumbing • Answered on Apr 29, 2023
2answers
I have a pioneer pressure balance tub and shower faucet and the cold water has stopped coming out?
You need to replace the pressure balancing spool cartridge.
4/21/2023 5:55:48 PM • Plumbing • Answered on Apr 21, 2023
Fix shower diverter pfister
replace spout amazon,home depot lowe's plumbing supply
4/19/2023 12:25:59 AM • Plumbing • Answered on Apr 19, 2023
2answers
Can a Pantry Faucet can use as Bathroom Tap?
yes you can
4/17/2023 11:16:04 AM • Plumbing • Answered on Apr 17, 2023
2answers
How and from were I have to release air trapped in to the pump
air will not be trapped in the pump. what you have to do is prime the pump so that the vacuum is filled with water the vacuum is created by expelling water which in turn sucks in more water and so on. if the pump is full of air ,there is nothing to expel and so no water is sucked up there should be a plug at the top of the pump for the purpose of priming. remove it , fill the pump and suction line and replace the plug
4/10/2023 9:55:45 PM • Plumbing • Answered on Apr 10, 2023
Yellow jacket 93560 SuperEvac 6 CFM Vacuum Pump Logo
1 questions posted
Top Yellow jacket Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Yellow jacket Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Yellow jacket Plumbing
Most Popular Question
lg intello air conditioner user mannual
  • Plumbing
