20 Most Recent Kodak EASYSHARE G610 Thermal Printer Questions & Answers
Cant get new ink cartridge to go in
Probably a piece of the old one is obstring it.
12/25/2017 9:39:37 PM • Kodak EASYSHARE... • Answered on Dec 25, 2017
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
5/13/2017 9:47:05 AM • Kodak EASYSHARE... • Answered on May 13, 2017
2answers
My kodak g610 is not printing ink on paper and i
It sounds funny but I have seen this so try it.Have you removed the protective strip on the contacts of the cartridge? the bare contacts must touch the printers.If I didn't see this happen I would not post it,it does.Many people in a rush to install make this mistake.Good Luck.
2/19/2013 3:41:25 AM • Kodak EASYSHARE... • Answered on Feb 19, 2013
Printer dock G610 won't print.
printer doesnot print
9/19/2011 4:46:00 PM • Kodak EASYSHARE... • Answered on Sep 19, 2011
Kodak Easyshare G610 printer dock; feeder stopped
Are you using a thermal paper when printing? If you are, then this most probably a problem printer head problem.
hope this helps.
7/15/2011 2:30:01 AM • Kodak EASYSHARE... • Answered on Jul 15, 2011
2answers
Can't remove used ink cartridge from G600 Printer dock???
Hold the transfer button down then hold the left arrow. Make sure the printer is on. Should here some clicking noise. When it completes then remove the ink cartridge.
11/12/2010 4:47:36 PM • Kodak EASYSHARE... • Answered on Nov 12, 2010
When i dock my camera it shows i have no pictures
reinstall its drivers if it doesn't work then tell me i will tell you another solution thank you for your queston.
8/19/2010 2:57:35 PM • Kodak EASYSHARE... • Answered on Aug 19, 2010
Cant pick up paper
the dock will not pick up paper lost my manual i tried one piece half full tray and afull tray it worked last time i printed what up
it keeps saing its out of paper
7/20/2010 2:41:20 PM • Kodak EASYSHARE... • Answered on Jul 20, 2010
I have changed the ink cartridges but the printer
Have you tried cleaning the print heads? The printer should have a function to do this...consult your manual would be my best guess
4/16/2010 1:30:25 AM • Kodak EASYSHARE... • Answered on Apr 16, 2010
When i dock my camera to the printer it keeps
ok! just make sure that you restart your printer and your computer to make sure that your drivers are recognizing your pc unit or laptop once thats done make sure that you do a test page on your printer and once that done make sure that the drivers work from your port on your printer try that and the hit me back..
3/26/2010 2:06:28 PM • Kodak EASYSHARE... • Answered on Mar 26, 2010
The printer will not pull photo paper through and
Had same prob with G600, all i had to do to get it working again was to clean the rollers with a damp cloth to get it working again.
12/14/2009 3:03:50 PM • Kodak EASYSHARE... • Answered on Dec 14, 2009
Replaced ink cartridge turned dial get pink and
A lot of times you need to do more than clean sensors to get results. You are getting yellow and pink because either soe colours (blue & black) are dried at the nuzzle or finished.
The procedure am giving you below will determine which is the case.
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
12/8/2009 9:57:28 PM • Kodak EASYSHARE... • Answered on Dec 08, 2009
Recive a message to replace color cartage and it
Replace the colour cartridge,
or use Windows to configure your printer to print "black only".
12/8/2009 2:49:42 AM • Kodak EASYSHARE... • Answered on Dec 08, 2009
Kodak EASYSHARE G610 Thermal Printer Logo
Popular Tags
65 questions posted
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
  • Office Equipment & Supplies
